Question about Exercise & Fitness
I have reference # 32707828. My fitbit blaze is still not charging properly even if I uninstalled the fitbit app from my phone. I need ti charge the unit every other day
Posted by Marika Alarcio on
3 Related Answers
Anonymous
  • 43 Answers
SOURCE: Phone wont charge
plug it into and see if it is connect...if not let me know
Posted on Nov 21, 2007
nexrad_chris
  • 123 Answers
SOURCE: My fitbit blaze no longer tracks my heart rate as of 3 days ago. Everything else works fine.
I would try cleaning the sensor with a bit of rubbing alcohol and a soft swab. Once it is dry try using it and see if it starts working. If that does not work you can contact Fit Bit and see if your unit is under warranty.
Posted on Sep 07, 2016
Dan Apthorp
  • 2824 Answers
SOURCE: My Fitbit blaze will not hold a charge. It is about a year old. What do I need if anything?
I am wondering if you have a bad battery.
Posted on Jul 16, 2018
I'm trying to install my Blaze Fitbit but it just keeps searching. What can I try?
Uninstall the app. Turn phone off. Turn on and reinstall. Then setup.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 29, 2018 | Miscellaneous
I have a wireless sync dongle, I want to set up my Fitbit how do I proceed
info i was able to find i hope it helps
When do I need the wireless sync dongle?
Fitbit Store.
Note that Blaze customers who want to use a computer don't need a dongle if these conditions are met:
  • The computer is running Windows 10.
  • The Fitbit app for Windows 10 is installed.
  • Blaze is in the charging cradle.
  • The other end of the cradle is plugged into a USB port on the computer.
In this scenario syncing occurs while Blaze is in the charging cable. It only works in conjunction with the Fitbit app for Windows 10.
Oct 28, 2017 | Exercise & Fitness
New Fitbit blaze fully charged will not work when in watch screen only comes on when on charge
How to Charge Fitbit Blaze: Step-By-Step
  • Plug in the charging cable into the USB port of your computer.
  • Find the tracker from the wristband. To do so, impulse the screen slightly so that it removes from the frame.
  • Place the tracker inside the charging cradle with the screen in front of you and the four gold prongs associated.
  • Adjacent the cradle cover.
  • Watch for a large battery icon that acts momentarily on display to let you know that charging has in progress. It gives a hint of how low your battery is to start, and a small battery icon persists in the top left corner while charging so you can check progress. When the green battery icon is fulfilled, then your Fitbit Blaze is fully charged.
How to Charge Fitbit Blaze The Definitive Guide for you
Sep 20, 2017 | Exercise & Fitness
Instructions on how to charge a fitbit 405
Many of Fitbit users and (maybe) you also facing problems with their Fitbit device, and may be you do not know how to fix it, or you are asking yourself How to Charge Fitbit Blaze You or any problem you are facing with Fitbit (Any Version)? May be you are also looking for somebody to fix the problem instead of yourself, but you do not have enough money or time for that cause when somebody is going to set that they will charge you money to fix your problem. Hope here you will get your solution.
Aug 06, 2017 | Exercise & Fitness
Exercise & Fitness Logo
136 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
