Mitsubushi heavy industries FDT71KXE6F fan motor won't turn on
Shows no error code cassette just won't run
Posted by Lesroy Arthur on
1 Related Answer
multilinkent
HTS Sri Aman
  • 739 Answers
SOURCE: Unicorn Industrial Sewing Machine Md.LS2-H5100
Hi..
Try to do troubleshooting to identify problems occur.
Brother Computer Codes
E1: Make sure the presser foot is lowered before sewing.
E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Sewing Machine Does Not Work
Check that the machine is plugged in and that the main power switch is turned on. The machine will also not work if the bobbin winder shaft is pushed to the right or if you are not using the foot controller properly.
Needles Break
Make sure the needle is fitted properly and that the needle clamp is not loose. Bent or blunt needles will also cause needle breakage. If everything else is OK, make sure you have the right size needle for the thickness of the fabric. Using the wrong presser foot for different types of stitches will also cause needle breakage. Check the owner's manual or the computer screen readout to make sure you have the proper presser foot for the stitch you have programmed in.
Other things that may cause needle breakage include scratches around the hole in the needle plate, pulling the fabric too tight, a scratched bobbin case and the wrong bobbin type for the machine.
Thread Breakage
Make sure the machine is threaded properly and that there are no knots or tangles in the thread. Check the needle to make sure you are using the proper needle for the thickness of the thread. If the thread tension is too tight, the upper thread will also break. A bent or blunt needle will cause thread breakage in addition to needle breakage.
Skipped Stitches
If you are noticing skipped stitches, make sure the upper thread is threaded properly and that the needle is not blunt or bent. Remove the needle plate and clean any dust out from under the plate or in the bobbin case.
Reference
http://www.brother-usa.com/manuals/default.aspx
hopefully this can help solve your problems
regards
Posted on Aug 13, 2011
What does it mean when there is E11 code on radio face of 2000 Buick lasabre
Cassette Errors
E10 : Tight tape error
Cause: A restricted cassette tape transport or broken cassette drive belt
Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco® Service Center.
May 04, 2018 | Buick Cars & Trucks
What is the e10 error code on the stereo
Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco Service Center.
If you cannot get the cassette player fixed I would recommend replacing the radio instead of going to a service center as it would be cheaper.
Jun 04, 2014 | 1998 Oldsmobile Cutlass
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
Error code 00 Buick century
try another mp3 player if that doest help its the raidio/ cd/ cassete unit
Jun 13, 2012 | 1999 Buick Century
My 2005 PT Cruiser shows error codes P0508, P0688, and P0522. Sometimes it runs well, and other times it runs rough then dies and won't start back.
this obd2 trouble code table can help u understand the meaning of code.
po522, the possible solution:
The most likely cause is a faulty oil pressure sensor/switch.
for p0688, you can Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
Aug 15, 2011 | 2005 Chrysler PT Cruiser
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Sony DCR-TRV19 Problem: None of the functions except cassette ejection will work. Error Code:C:31:23
Error code 31:23 shows problem in Take-up Reel section of your Sony Camera. If you know about camera repair, please check Take-up Reel section in tape mechanism and if you don't know, please contact nearest Sony Service Center for proper repair.
Aug 17, 2008 | Cameras
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
57 people viewed this question
jasbo
jasbo
Marvin
Marvin
