Question about Samsung Televison & Video
Samsung UN65K850DFXZA Version FA01 display has a vertical black block but no physical cracks on the screen. Is it possible to be repaired? If so what part has to be replaced?
Posted by Ravi on
City View TV & Computer, Inc.
    Master:
  • Samsung Master
  • 450 Answers
It is a possible defective data buffer IC on the LCD panel flex cable, if so, it could not be repaired, you need a new LCD panel.
Posted on Nov 01, 2019
5 Related Answers
Anonymous
  • 179 Answers
SOURCE: 50inch Samsung DLP with black vertical line on right of screen
the light tunnel has come unglued..samsung has had a problem with this in the last few years...to be absolutely certain of which part i would need the complete model number and the version number which is on a small sticker on the right side when facing the front of the set..i am fairley sure the part number is BP96-01961A. this is not the easiest job to do and you might want to contact a technician who has done one before...what city do you live in?
Posted on Nov 29, 2007
Anonymous
  • 66 Answers
SOURCE: Samsung SGH-D600 LCD screen replacement
if u still need the instructions on how to open the phone n replace the lcd msg me, but i suggest u buy a working new LCD first
Posted on Mar 13, 2008
Anonymous
SOURCE: outside LCD screen cracked
best solution would be using a cutter to unglue the external screen and replacing it with even a class B external screen for nokia 5310 express music phone that comes with a whose outer shell set.its a like a snap-on cover set. it comes cheap so why not. then just put the new external screen as to where the old one was. glue it up and you;re done.remember to be extremely careful not to poke the lcd screen with your blade.
Posted on Oct 22, 2008
Anonymous
SOURCE: broken flat screen tv
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
Posted on Feb 20, 2009
Anonymous
SOURCE: Samsung 50 inch Plasma cracked
Same model 14 months old cracked panel from inside, bought 2 year warrant waiting to find out if they will replace it ?
Posted on Nov 12, 2009
Samsung UN49KS8000FXZA Version FA01 Video Not Working
It could be one of 3 things, main board, tcon board or a bad panel, does the menu look normal or does it have vert lines going through it ?
Which components might be bad in my Samsung LED UN65NU6900FXZA FA01 tv?
This can be caused by a loose connection on any of the cables to the display or it maybe a failed connection that is soldered at the edge of the display. If you take your thumb and apply pressure to the edge of the display all the way around in different spots and the line vanishes, it is the actual lcd edge.
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
RRght 1/3 of screen had vertical lines, now solid black.
that is most likely going to require a new display. what is the model, version, and serial number for the tv? I may be able to help.
NO VERTICAL DISPLAY
Hey the Vertical section circute of the TV needs physical repair
or if there is a V-Hold pre set behind the TV you need to set it.
regards
1helpful
I have a samsung hd lcd tv. When it's turned on it looks cracked.
There are no settings that could produce that result.
On most LCD TVs there is a LCD controller board that controls the vertical/horizontal display output. It sounds like your LCD controller has failed.
When you say 'appears to be cracked'...you mean it is actually physically cracked? That is a different issue altogether. I would say 99.9% of screen fractures are due to rough handling or a stray impact with a Wii controller, but rarely screens can fracture due to manufacturing defect or a sudden change in temperature or altitude.
7helpful
4answers
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
1helpful
Samsung YP-P2 cracked screen
hi! i had a cracked screen too the only way i could repair it is to send to samsung they repair it free! if it broke on physical use then they will charge u.
Open Questions:
Televison & Video Logo
Ekse
 Francisco Mauricio...
