Question about Magellan GPS
My Magellan 315 will not find satellites. - Magellan GPS
Posted by Tony on
5 Related Answers
Anonymous
SOURCE: Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Posted on Jul 25, 2007
Anonymous
SOURCE: Case cracking Magellan 315
I was able to open a 315 by starting at the bottom with a screw-driver placed in the gap between either of the two cross ridges and twisting the screw-driver.This opened a gap at the bottom which I followed around the perimeter with the screw-driver until both halves seperated fairly easily.
Posted on Jan 02, 2008
Gary G
  • 4 Answers
SOURCE: MAGELLAN GPS 315, LCD Not filling out completely
I just got my GPS 315 open, thought it may have zebra connectors.
You will break the wires from the data connector in opening this beast. There is a photo on this site showing the wiring.
It is a wired panel the connections to the LCD uses some super adhesive that gives way after a time. It appears unrepairable.
I have two early 7 inch LCD TVs with the same problem.
There is NO markings as to part number or manufacture so the panel
will be unavailable. So I would suggest to use it as is or use it with an early laptop with a serial com port.
Gary G
Posted on May 26, 2009
aloha27
Steve
  • 696 Answers
SOURCE: manual for magellan gps 315
Hi1 Here's the link for your manual!
http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Posted on Apr 10, 2010
Anonymous
  • 677 Answers
SOURCE: AM LOOKING FOR A MANUAL FOR MAGELLAN GPS 315
(magellangps.com/support/product.asp?prodid=2)
You can use this link to download manual.
Posted on Jul 30, 2010
Magellan 315 lines across scree
if those lines are vertical it simply means that your batteries are weak. you could try cleaning the contacts careful - battery ends as well
May 14, 2012 | Magellan 12, 310, 315, 320
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
I need a user guide Magellan 315 for (PDF File)
here is the link to your manual http://oneresponse.info/resources/imtoolbox/publicdocuments/GPS%20-%20Magellan%20315320.Pdf
May 08, 2011 | Magellan 12, 310, 315, 320
Apr 24, 2010 | Magellan GPS 315 GPS Receiver
Gary G
Apr 14, 2009 | Magellan GPS 315 GPS Receiver
The only method I have found is with a dremmel tool and cut it open along the original split line.
All the electronics are clear of the case mid line. The case is a bit less than 3mm thick.
The antenna is closest with maybe a 2 mm clearance all round and the various (6) rear conector wires (on the right looking from the back) have a similar clearance but sit below and away when the unit is assembled. Cheers
Dec 16, 2007 | Magellan GPS 315 GPS Receiver
Magellan 315 won't find satellites.
I have one of these units and it too is experiencing the same problem. I have talked to one geocacher and he thinks it could be the connection to the antennae that is now broken. He has a different Magellan unit and he had to fix the antennae connection. I was going to try that on my unit, but I need to figure out how to open it. Hopefully this helps. If I find out more I will let you know. Greg
Aug 15, 2007 | Magellan GPS 315 GPS Receiver
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
GPS Logo
126 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
