Question about GPX Audio Players & Recorders
How do I unlock the transit screw on the CD PLayer on my GPX Stereo Model S7799?
Posted by Mike Donnelly Elder on
Larry Stiles
    Champion:
  • 301 Answers
Most of those types of screws only require a 1/2 turn to unlock.
Posted on Dec 11, 2019
5 Related Answers
Anonymous
SOURCE: Need owner's manual for GPX under-cabinet radio CD player
http://www.gpx.com/
then go to support
Posted on Dec 26, 2008
Anonymous
  • 835 Answers
SOURCE: I have a Ford Escape 2008 model - after a service,
yeah they should be able to unlock the stero /unhooking battery without retreiving codes will lock up stereo . i would tell them get codes or get new stereo
Posted on Nov 05, 2010
RixsFixes
Radio Code Pro
  • 2200 Answers
SOURCE: i need a manual ford
Please visit this link where you can download this radio manual for free.
Thanks for using FixYa and please do leave a vote for the solution.
Posted on Feb 02, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: need manual for GPX MODEL
http://www.retrevo.com/support/GPX-KCCD6316DT-Clock-Radios-manual/id/1183dj690/t/2/
Register for free at retrevo.com
Posted on Feb 06, 2011
Greg Kosmo
SOURCE: GPX MP3
If your car has a tape player, you could but a converter for a couple bucks that plugs into the earphone jack. Otherwise, if you don't have an audio-in port, you would have to get a new radio console thingy.
Posted on Oct 22, 2012
Ford Transit Stereo 6500 CD Code
We have no access to the factory data base that contains this secure information, remember this is an anti theft code.
May 24, 2012 | Ford Transit Cars & Trucks
What are transit screws for a xd1225 and what will happen if u dont remove them
The transit screws are for locking the CD mechanism when it is shipped from the factory. Most of the Car CD players have floating suspension for the CD transport mechanism. This prevents CD skipping when you are traveling off road or when driving on bad roads. The CD mechanism has four shock absorbers or dampers fitted underneath . The Transit screws tighten these dampers and make them stiff ( in other words no soft action ), so if you forget to loosen them and travel through a bad road the CD might skip. On good roads one might not even realize the difference.
Mar 28, 2011 | Dual XDM-6820 CD Player
The transit screws keep the components from moving and getting damaged during moving or shipping. The unit will not operate if these screws are not removed.
My tape deck doesn't play the tapes correctly. It plays them slow or doesn't play them at all. What can I do to correct this?
you either have a bad cassette motor or the belt has stretched to the point that it can't play them at normal speed will need to be changed.
Jan 03, 2011 | GPX S7799 Shelf System
How do you program the cd to the GPX home stereo system
How do you program FM stations on the old model GPX s7794 model. I do not have a remote. Thank you!
Dec 19, 2010 | GPX HM3817DTBLK Shelf System
What are the correct speaker connectors for this unit RCA, Phono ,3.5 mm ?
Does it have a speaker output - I'm sure it does? More likely it's the 3.5mm. which may look like for headphones. The RCA are for low level signals so therefore it's not for the speakers. Do the speakers have two wires a piece? If they are, then there should be speaker output clips on the stereo to connect to. If they look like phono plugs then they go into the speaker output jacks.
Oct 25, 2010 | GPX S7799 Shelf System
GPX MP3
I would like an answer regarding connecting gpx mw3837 to car stereo to use cars speakers.
Jan 07, 2008 | GPX M2104 MP3 Player
Top GPX Audio Players & Recorders Experts
Jean Sintulaire
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
