Model is a 2yu65 dayton heater you can hold the contactor in manually and everything works but wont pull in when you call for heat
SOURCE: intertherm outside unit - s3ba-036k - does not run
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
SOURCE: 1VCF2 Dayton Oscillating Wall Fan
The speed control switch which is what the cord is attached to has gone bad. You can get these from grainger.com for the dayton line of fans.
Hope this helps
SOURCE: dayton unit heater
Dayton heaters are a product sold by Grainger. Contact them for a manual.
SOURCE: Contactor not engaging to start condenser unit
I would replace the contactor if you are getting 24 volts to the contactor and it isn't engaging therefore the magneto on the contactor is out and the contactor will need replacement. If you don't have 24 volts at the contactor then the transformer that sends the 24 volts is bad and will need replacing
Dave
SOURCE: My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
