Question about Furniture
Wine Enthusiast N'Finity 170 bottle two-temp error code C1?
Posted by A Brady on
2 Related Answers
Sheldon Dedek
  • 909 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
tgmusicgirl
Lisa
  • 101 Answers
SOURCE: My 18 Bottle 2 temp wine enthusiast frig start beeping and blinking
Did you unplug for 10 seconds... then plug it back in?
Do you have any control over the front panel?
Can you verify after all of this, that the back cooling fan is working?
Their is a sensor in the back of the cabinet that monitors overheating of the thermoelectric unit... Unplugging it for a while and powering it back up is one way to verify this...
you can put a fan where the vents are in the back to speed this up...
Posted on Aug 18, 2018
Testimonial: "Thanks for your reply. I did all of that but it did not work. Yes there is digital front control panel and blinking. Also the fans are not working."
Need a defrost sensor, where can I buy one?
Try a local parts store or you can find it online at repairclinic.com
Nov 16, 2015 | Wine Enthusiast 42 Bottle Double Door Dual...
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
I have a "the wine enthusiast" wine cooler and it's a 2001 model 2720216, 16 bottle storage, and it is not cooling the temperature stays at 80 degrees can it be fix or just get rid of it and buy a new one?
At that temp I'm sorry to say sounds like the compressor is shot or all the gas has leaked out. A service call is about $100.00 to ring the door bell and then add about $500.00-600.00 for a compressor and or 300.00 if the coil is bad. It might be better to get a new box with a warranty. Best of luck!
Aug 23, 2010 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
Nov 02, 2009 | Refrigerators
Furniture Logo
140 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
