Computers & Internet Logo
Question about CIPHERLAB Computers & Internet
Hi, my Cipherlab 8000 turned off while I was working and now, after so many attempts, it doesn't turn on anymore, what can I do?
Posted by alocin on
Larry Ng
    Top Expert:
  • CIPHERLAB Master
  • 11,204 Answers
What is it? is it a computer posted to computers.
huge 200page manual (first google hit )
its a system , not 1 thing, right,
a host and mobile computers.
which of these is your system.
Receiving in Retail Price Check Product labeling & Tracking Shelf Product Replenishment Mobile Point of Sale (POS) Mobile Inventory Management Order Picking & Staging Work-In-Process Tracking Material Flow Control Transportation & Distribution Warehousing Asset Management
what part of the system are you hands touching, IDK>
Posted on Dec 17, 2019
My CipherLab 8000 not scan the barcode.laser are open but can't scan.Could you please find out the solution.Thank you.
May be some one doing by mistake disable for all types of bar code ( not enabled ) or all sympologies.
How do I insert comma into the scanned data of a cipherlab 8000?
If you using Forge, you could chose between comma or dot for decimal inputs in the latest versions of Forge.
Earlier just a dot were available.
How do I get the craddle to turn on
It depend of model of your cradle:
If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda.
Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda.
The driver need to be installed before connect the cradle to computers USB-port.
Cipherlab cl8200 timeout error? when exporting to hand held?
9f76079d-6fa0-4db9-9587-a2e27f8ce81a.jpg in the lookup section . select the following
that should solve the timeout problem
1helpful
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
2helpful
Hello! I have a problem when programing the CipherLab 8001-C Application Program (AG8000N.exe). The download start (terminal bip) and after 3-4 sec show "Download Complete" but the terminal show the...
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
Top CIPHERLAB Computers & Internet Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Larry Ng
Larry Ng
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
