Question about Refrigerators
Kitchen Aid 48” built in. refrigerator, Model KSSC48QVS05 Arch. Series, heard snap when opening.(spring) fridge.Light does not turn on when refrigerator door is opened and door open red light flashing
Solved: 1. Light switches for both refrigerator and freezer are located behind top panel (Remove Top panel). 2. Look for screw that has fallen out and replace in henge actuator linkage. 3. Replace spring. 4. Reattach top panel. Quick fix.
Posted by John Hooser on
1 Related Answer
Thomas Beaver
  • 2119 Answers
SOURCE: Kitchen Aid KSSS42QMB Heard something snap, when
Light Switch broken?
In cabinet parts diagram part 44 for refrigerator side, I would guess that there is one on the freezer side too.
KITCHENAID Built In Refrigerator Parts Model KSSS42QMB00
Posted on Sep 29, 2014
Switches on kitchen aid refrigerator dispensers not working.. ice maker is working, but will not dispense ice or water
Sounds like the water has been turned off, or the solenoid valve (located at water entrance to fridge) has failed. you should hear a solid snap from that solenoid when water is called for by pressing the dispensing switch. You can test the solenoid by unplugging the fridge and measure the resistance across the solenoid terminals. If it measures 200-500 ohms it is ok. if it measures open the solenoid has failed and needs to be replaced.
Sep 18, 2014 | KitchenAid Refrigerators
KITCHEN AID MIXER K5SS has a banging noise when turned on how would I find out how to fix it ?
You will need to open it up and inspect the brushes carefully. Look for a little copper wire, this wire needs to be firmly attached to both the brush and the little disc at the other end of the spring. Clean the brush out with a can of electric cleaner to free any dirt that has built up around the gears.
Jan 04, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid Model KUDPQ1FLSS5 door counterbalance issue
One of the counter bakance springs OR the adjuster for it let go. I had a similar thing where the adjuster which was a thin metal "T" thing that screwed up into the spring as an adjuster folded and fell out of the spring.
Remove the bottom dress cover at the tope kick of the dishwasher. The springs are all accessable right there. The problem will be obvious. Just compare the two sides.
I had to beef up the "T" adjsuter in mine as it was too weak to continue holding in the spring.
One turns it into more or less coils of the spring to adjust the counterbalance.
Apr 21, 2010 | KitchenAid Dishwashers
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
