Hello Gayle,
I found this video and I hope it helps you out.
https://www.youtube.com/watch?v=wWOubLQ5luc
Good luck,
Andrew
SOURCE: looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
SOURCE: Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
SOURCE: how to remove staples from bostitch T5 model
Lift the hinged guard on the front of the stapler and while open use a pencil or similar object to depress the striker (above the staples). This will release the spring catch and the staples will move forward. Use caution and catch the staples as they come out under spring pressure.
SOURCE: I have a very old Bostitch staple gun Model T5.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
