HP Laserjet 5000 on a network. Was working fine, had to move it. Now it seems OK but shows status of Offline on computer (Printer says Ready). I have tried the data jacks and they are live and computers connected to same jacks connect. Have also tried a different cable. Nothing was changed except the location in the same room and network(and it was off for a few days while we moved).
Please verify the workstation (or server) is not set to "use printer offline", I also suggest trying to ping the ip address of the printer or trying to access the webinterface of the printer by going to printers ip address in a web browser.
Please let me know if this fixes your problem or if I can be of further assistance. Thank you.
Please run the Self-Test on the printer. You will get a printout and look for the following items:
If you've still not determined the problem, you'll need to verify the cabling - get a long cable and plug the printer into a jack where there is a functional workstation or plug in a functional workstation to the jack where the printer is located. Verify the connection at the switch - try a different port. IP Address: let's verify you and the printer are using the same address.
TX Packets/RX Packets (or similar): let's see if the printer is sending and receiving packets. Neither of these values should be 0.
Please keep me posted on your progress.
SOURCE: printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
SOURCE: Can't print because of Error-offline status.
Hi
To fix the problem permanently try the below solution, you will not experience this anymore.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP photosmart C6100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
SOURCE: Printer status offline
There is a firmware update for this problem. Check out this link:
http://www.hp.com/pond/firmware/hidden/P2015FWUpg20080312.html
SOURCE: HP Color LaserJet 2605dn is ready - but folder
it is problem your printer driver is not properly install or data cable is unpluged
Some more info --- we tried to ping the IP address for the printer with no luck.
