Question about Measuring Tools & Sensors
What can i do to modify my B&S Intek V-Twin OHV 21.0 h.p. engine to produce max horsepower. Im wanting to build my son a offroad racemower and would like to modify this motor properly
Posted by Dakota Rogers on
5 Related Answers
ollie reece
ollie reece-jones
  • 1167 Answers
SOURCE: Factory horsepower specs for a 1982 Yamaha Seca 400.
hi buddy its [email protected]
Posted on Oct 07, 2009
Anonymous
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
Mike Roberts
  • 395 Answers
SOURCE: Briggs and Stratton Intek V
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Posted on Sep 17, 2010
Anonymous
  • 59 Answers
SOURCE: Bent push rods both cylinders,engine # 445677-0827-B1
You can find a manual, free of charge at www. briggs & stratton.com. click on manuals and put in your model and type and its free to d/l. You can then print it out if so desired.
Posted on Sep 23, 2010
Anonymous
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: will only start with choke on and after warm (chok...
If it has a plastic intake manifold there is your culprit. The flanges warp and produce vacuum leaks and all three.
Posted on Nov 06, 2010
205cc = ? hp
I am sorry, but these do not equate. cc (cubic centimeter) is a measure of volume, hp (horsepower) is a measure of power, like watts. There are many factors beyond the cubic centimeter displacement of an engine and the determination of horsepower.
Kevin D
Dec 22, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Is there a conversion chart to cc to horsepower?
No. Cubic centimeter (cc) is a unit of volume. Horsepower is a unit of power. Two different 250 cc engines, for example, may put out different amounts of power, while 250 cc of sand won't put out very much.
Oct 22, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Wheres oil drain on 21 hp intek briggs
you should have a square plug on the side of the block usually on the starter side of engine
Aug 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do you time a 20 horsepower intex engine
i believe the ignition timing is not adjustable , if you think you might have a timing issue you need to chech if flywheel keyway is twisted or sheared
Mar 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Stratton Briggs Stratton Intek V - Twin Engine 21 hp oil had white foam in it
The oil is contaminated with water. Change oil and filter, if it has one.
Jun 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
1854-Yamaha V-Twin Motorcycle Engine
The horsepower of that mighty beast is exactly 100 horsepower (73.6 kW). Here's some of the other specs:
  • Engine Type - Air cooled, 4-stroke, V-twin engine, OHV, 4 valves
  • Displacement - 1,854 cc
  • Bore & stroke - 100 x 118 mm
  • Compression Ratio - 9.5:1
  • Max. power - 73.60 kW (100 HP) @ 4,250 rpm
  • Max. torque - 167.80 Nm (17.1 kg-m) @ 2,500 rpm
  • Jan 17, 2009 | 2006 Yamaha Roadliner
    Measuring Tools & Sensors Logo
    110 people viewed this question
    Top Measuring Tools & Sensors Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
