Question about Haier Heating & Cooling
Hi Can you tell me why my haier a/c model HSU12XHKW Doesn’t cool / heat at all only fun I guess Last time I know hi was running very well that morning my gf call me and said a/c not on , I mean no power dead. I said go chk the breaker and I was right , long story short every time breaker on after 1 min off again Now cone the part that I don’t like it’s that I change the breaker from 15 amp to 20 amp and the power stays ON ... but no heat no cool at all only air PLEASE Tk u
Posted by Roy Marusi on
David Spradling
    Top Expert:
  • Haier Master
  • 10,974 Answers
Possible fan motor or compressor drawing too much amps see if start up capacitors weak or bad motors
Posted on Dec 24, 2019
5 Related Answers
Michael Anderson
  • 172 Answers
SOURCE: Power Working fine but keeps shutting off
Hi jenniferlahm,
This type problem usually shows it mean head when your motor is going bad. The motor will run for just a moment then it gets really hot and shuts off till cool. I bet when you start the dryer you hear a unusuall humm as the motor starts. If you are not hearing a hestating humm as it starts then the problem may be elsewhere. Other possible problems that casue this would be. the tub rollers. To check the rollers reach inside and try to turn the tub with your hand. you should be able to turn the tub. if not you may need new rollers, or pads. Good luck and I hope its not a bad motor, but if it is let me know and I can have you one there in no time.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
Anonymous
  • 90 Answers
SOURCE: Runs short time,quits,wait 20 min, runs again for a few min.
Hello, It sounds like there is a problem with the electrical portion of the tiller. Once the internal coil heats up it looses the power to keep the engine running. The other option is the muffler that is overheating the carburetor to the point that it boils the gas before it gets to the engine. A lot of the older B.&S. engines used a two piece muffler with a screen inside that would get plugged up causing excessive heat to the carburetor. Good Luck, RAC
The Guest's problem is quite different. You should have throtlle cable coming down below the carburetor on the side of the B.&S. engine. Not knowing which type of govenor you have on the engine, early models had a metal plate that was controlled by the cooling air of the engine and later models had a mechanical govenor built into the side of the engine. Is sounds like the govenor is stuck at full throttle for one thing and the engine is running out of gas because it can't flow enough fuel to the motor. This type of problem can also be caused by a loose carburetor causing a vaccum leak or bad gaskets on the carburetor. I would rebuild the carburetor and insure all ports are clean and flowing, including the small screens on the bottom ot the fuel tubes, replace carb gaskets and check the carb. insulator to make sure it is not cracked also. While it is apart check the throttle linkage elements to insure they are free before reassembling the carb. back on the engine. Good Luck, RAC
Posted on Apr 18, 2009
Anonymous
  • 9 Answers
SOURCE: CAR CUT OFF AND ACTS UP WHEN DRIVING 20 MIN..
Check the ignition coil or coil packs. It sounds like overheating coil(s)
Posted on Jun 14, 2009
Joe Hogan
  • 10865 Answers
SOURCE: dometic rv air conditioner over 100 deg. trips breaker.
The problem is that when u add up the electrical draw from all of these appliances running full bore, your draw exceeds your available amperage. Now you are doing the math and saying no...... Let me tell you why. It is rare to find a situation where a 100 amp service actually porovides 100 amps. You almost always have voltage dropo. And when you are adding extension cords to the mix the drop is even more. That said, When you are using the AC try to minimize the use of other appliances, especially the microwave which is a big draw too.
Posted on Jun 25, 2009
Anonymous
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 11, 2011 | Dryers
Our Haier dehumidifier, Model HD306 seems to be working okay except it is not gathering any water. Last year we had to empty the bucket every two days. The humidifier is in the same spot and under the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 18, 2011 | Haier Dehumidifiers
Have a Haier 5.3 cu.ft. about 1.5 yrs. old. It freezes ok and cycles off ok, but it doesn't cycle back on unless I tap it near the control. If it doesn't call for more cooling it won't cycle on...
The thermostat is bad....
You will need to replace that t-stat..
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 17, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
heatman101
May 12, 2011 | Haier Dehumidifiers
Why my model HTZ21 JICR55 HAIER IS FROZEN AT THE REFRIGERATOR BOTTON/
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2011 | Haier Refrigerators
Heat pump is in heat mode 4 hrs. in to the
Hi, this is your programmable thermostat not being programmed right. If you have the manual, set your times and temperatures for both heating and cooling to cool or heat at the times you want it to. I am not sure where you are, and if you want to use just heat or cool, but you can set it to run on just one or the other, or to auto change over. Just be sure to run it in the auto mode. I can't tell you how to over the net as there are so many models of thermostats, but if no manual, you may be able to get one by getting the model number off your stat and name, go to a place that sells that stat and they can tell or show you how to set it up. I hope this has been of help to you. Let me know please.
Shastalaker7
Dec 23, 2009 | Ruud Handle Air Conditioner
Cooling
Not knowing what region you live in, I can only guess that it may not be warm enough for the cold control to activate the compressor.
I live in N,W, Ohio and it has not even been close to needing an
A/C
May 27, 2008 | Haier Heating & Cooling
Through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Sep 10, 2007 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Larry Blais
Larry Blais
Peter Schmidt
Peter Schmidt
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
