Question about Refrigerators
Water dispenser is continually flowing & won't turn off!
Posted by Sue Kleinman on
Jorgie Navito
    Master:
  • Refrigerators Master
  • 346 Answers
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
http://www.appliancerepair.net/refrigerator-repair-1.html
Posted on Mar 26, 2020
5 Related Answers
Anonymous
SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
Posted on Sep 15, 2007
docjohn174
john gagnon
  • 943 Answers
SOURCE: water doesn't stop
hi thanks for the question the problem seems to be a water valve especially a summer home sediment from well water gets stuck in the water valve or just a weak spring in the water valve i would replace the valve thanks the appliance doc
Posted on Sep 17, 2008
Mark Egan
  • 1214 Answers
SOURCE: water dispenser keeps dispensing water when not pressed
If you can pull on the lever to make water flow stop, chances are there is a mineral buildup inside the valve, or the seat in the valve has failed. Either way, the valve normally needs to be replaced as they are not usually serviceable. Leave the Model number of the refrigerator so that I can check what to replace.
Posted on Jan 15, 2009
Anonymous
  • 531 Answers
SOURCE: Ice dispenser works; water continuously flows from water spout
may be your water valve
Posted on Apr 05, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: water continues to flow after dispensing coffee
Sounds like there was a high pressure buildup at one time that affected the spring and valve in the grouphead. Remove the shower screen and then the 2 allen wrench screws, check the spring and valve to make sure it is seated properly.
Posted on Feb 21, 2010
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
Replaced water dispenser still not moving or getting water
sad but we can not look it up as were not given make or model
Mar 26, 2015 | Refrigerators
My water dispenser in my GE Adora stainless side by side refrigerator is not working
Water dispenser doesn't work
  1. Dispenser control board
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
  1. Water tube in door is frozen
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Why is my Water dispenser not working?
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Refrigerators
Kenmore ultra fresh side side 59507990
828a4e4f-c0b3-4029-a7f5-35b92db8b7ad.jpgKenmore model numbers look like this example=> 321.1234578 Are you sure that the water in the ice maker is melting and flowing down into the ice bin? What may be happening is the water control valve for the ice maker may be allowing water to continue flowing into the ice maker tray even when off due to the water control valve being defective. If your refrigerator also has a water dispenser and the water is not continuing to leak is because the water control valve has to sides. One side is for the ice maker and the other side is for the water dispenser. I am here if you have questions, Thanks Sea Breeze
May 29, 2013 | GE Refrigerators
Whirlpool side by side fridge won't dispense water.
Most likely the problem is related to a defective water control valve on the dispenser side of the valve. If your model is the ED2FHEXN it will use the=> W10408179 Water Inlet Valve
You should always turn the water supply off before removing the filter cartridge just to insure less water clean up should a water valve be stuck open. At this point I still believe that the water control valve is at fault for not allowing water flow to the dispenser. Here is a parts manual=> ED2FHEXN Parts Manual and here is a link to your ED2FHEXN User Manual You may get some water flow spraying should there be a valve stuck open but that is not the cause of you not getting water to the dispenser. Your ice maker is still working right? I will be here should you have questions or comments, Thanks Sea Breeze
Mar 05, 2013 | Whirlpool ED2FHEXN Side by Side...
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser keeps flowing when water source is turned on
HI,
I have a little experience on your problem.S i suggest you to ask another experts advice.
Jun 13, 2008 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
