Question about Furniture
Wine Enthusiast 48 bottle Model No 272480351 Fans not working
The fans at the rear of the unit are not working at all, only the ones inside the wine rack section inside the doors.
Posted by John Saunders on
2 Related Answers
Sheldon Dedek
  • 909 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
zappal
  • 256 Answers
SOURCE:
Are any of the heat sinks (Those large aluminum blocks that the fans are attached to) getting cold?
Posted on Oct 02, 2017
Wine Enthusiast Silent Wine Refrigerator is making a loud buzzing/whirring noise.
Since this unit doesn't use a compressor, the only moving parts are the whisper fans inside of it that circulate the air. One of those fans may be going bad. If you are handy you can remove the back to see if all the fans are working but your best bet is to use the one year warranty and have a qualified techncian figure it out.
Jan 07, 2014 | Refrigerators
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
My 12 bottle cooler is still cooling OK but it is making a strange loud throbbing or pulsating noise. Is there something I can do to stop this noise?
Mine is too. It\'s the fans they are very cheap and I don\'t think you can find a replacement for them. It\'s the usual stuff made in China that we Americans buy.
Jan 01, 2011 | Wine Enthusiast Silent 12 Bottle Wine...
Nov 02, 2009 | Refrigerators
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Furniture Logo
160 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
