Because you were clumsy, careless or just plain cack-handed. Diffuser on what camera, BTW ?Because you were clumsy, careless or just plain cack-handed. Diffuser on what camera, BTW ?
You can't post conmments that contain an email address.
May be defective nebulizer, or may need diffuser reinstalled. Inside bottom of neb cup (unscrew top half) is small plastic piece (diffuser) that mounts directly over the hose connector (on outside) U can pull the plastic piece up to make sure its not too tight ,can come out-just push back on- or push down if too loose (poor air flow stream) If the diffuser is lost or broken you need a new nebulizer. If home care company wants to charge you more, tell them they gave you a defective nebulizer. Im a retired RRT
Nowadays most of the people use the diffuser for dispersing aroma in room, car, and office premises. As you also looking for the best diffuser for doing the same then I would suggest you to just take a look at Oil Diffusers. This is one of the best websites where you can find all types of diffusers such as car diffuser, jewelry diffuser, room diffusers, and ultrasonic diffuser. I also purchase the ultrasonic diffuser from this website, they provide me the best quality of diffuser at an affordable price. You can also take the best diffuser from here.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife. I have also used a utility knife to cut a polystyrene diffuser cover originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture. In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs. Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose. You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
assuming that you have not defrosted the unit completely,do so (ice is 0c..and you want freezer to be -18c)then let unit settle for 24hours,then check temp...
Sony KP-57WS510 has 3 layers front screen and I do not know what layer is broken. Part number of all 3 screens are as follows.. count it as front, middle and rear screen layers..
