Question about Refrigerators
My interior light in my freezer is flashing slowly, I can't find any answers for this
Posted by Stacia Burnham on
  • Ronald Rissel Nov 03, 2019
    Hi Stacia Burnham, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Specifically, I need to know the brand and model number of your refrigerator or freezer. Also, does it use light bulbs or LED modules?
Light inside both fridge and freezer are flashing strobing
Maytag refrigerator control panel lights are flashing and the ...
www.shopyourway.com > Manage My Life > Questions
Maytag refrigerator control panel lights are flashing and the ice door opens and ....Took an hour or two since it was my first time taking the interior panels apart. ..... myfridge to what you suggested i buy (even thought both are 35V) and for the ...
Whirlpool Refrigerator Repair - Interior lights flicker ...
? 3:24
https://www.youtube.com/watch?v=0s4aQYNWzZs
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot a Whirlpool Refrigerator that has this following dilemmas: Interior lights flicker Only at http ...
Nov 02, 2015 | Computers & Internet
Model zx97/5si fridge freezer. Why are the interior light and compressor not working?
My question is whether these three LEDs steady light or flashing during normal mode?
25836454-ucy4wx0s13wzivwce2sy2wdr-4-0.jpg If all three LEDs flash, that means NTC sensors failure!
NTC evaporator sensor is placed on back side of battery evaporator and NTC ambient sensor is placed on front side of batery evaporator.
Battery evaporator is placed in freezer compartment.
Dado
Aug 25, 2015 | Zanussi Refrigerators
Fridge freezer gets warm every 24/48 hours
A few things to consider. What is he temp in the FF side of the unit? Putting a thermometer in a glass of water overnight on the bottom shelf should read 40F in the morning. If that's fine its cooling properly. Assuming your not opening and closing the doors excessively, you could have a leaking/bad door gasket or the interior light door switch has failed and is stuck in the on position, which would make the interior temp slowly rise. To check the door gasket, close the door on a dollar bill (at various places around the doors), slowly pull out the bill you should feel good resistance,, if it pulls out easily or no resistance is felt the door gasket is bad or door is misaligned. Also don't forget door gaskets and sealing surfaces need to be checked and cleaned regularly for them to seal properly.
Nov 04, 2014 | Refrigerators
I accidently turned off freezer.How do i turn it back on?
Turn the interior temperature control back on by setting at approx halfway between "off" and "coldest". (Make certain the branch circuit is hot - you should hear the compressor turn on when you set the control, possible an interior light will come on as well).
If the freezer does not run, check to see if you accidiently pulled the flash defrost plnger (if equipped). (See age 8 in your manual).
If you don't have a manual, you can download one here:
ShopYourWay KENMORE Upright Freezer ShopYourWay
(This is for Kenmore model 253.23024-101 or -102).
Apr 22, 2014 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temperature warning light came on. Removed
dear sir/madam
i think its tempretor sensor /thermostat problem please try to find thermostat needele and keep in right position , and check its tempretor satting if it,s need to reset please reset it . i hope after that it will working good. if not please try to contect your freezer maintanance perssonel for repair/reset your freezer .
hope answer the question.
thank you
please vote!
Jul 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lec freezer if i turn thr temperature up the red light starts to flash
that is because when you want a colder unit the sensor is detecting a warmer interior hence red warning light comes on.leave it at the setting you want and within 24 hours the red light will go off.
strongly recc you use a freezer temp gauge so you dont get rock hard ice cream(-18C is best)
Mar 23, 2010 | Freezers
INTERIOR LIGHT GOES ON AND OFF
next time it does this unplug for 20 mins and pcb will reset its self....
Sep 28, 2009 | Hoover HFA290K Bottom Freezer Refrigerator
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
