Question about Smeg Refrigerators
Smeg fab30 fridge freezer not working, both defrosted entirely
Posted by Georgi Roberts on
ray gallant
    Top Expert:
  • Smeg Master
  • 66,956 Answers
Call a repair service locally you need freon added to system
Posted on Mar 26, 2020
1 Related Answer
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: Hi, we just defrost our
some of these new fridges have a delay timer and can take up to 10 minutes to reset. check to see you have power at the plug.. use a hair drier low heat .. make sure the stat is set.. duh .. hey it happens to the best of us .. jay
Posted on Jul 23, 2011
FRIDGE
Your fridge is making condensation check the doors if it's closing properly I think the fresh air is going in side
Sep 06, 2014 | Smeg FAB30 Top Freezer Refrigerator
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Punctured freezer liner will fridge still work
NO, all the cold for the frig comes from the freezer. No separate cooling coil for the frig. You probably just killed your frig. I've never been able to repair a puncture line and recharge.
May 05, 2014 | Smeg FAB30 Top Freezer Refrigerator
Motor not runing properly
You need to make sure nothing is blocking the vent located in the back of your freezer, by removing all items you will have a better flow..
Aug 03, 2012 | Smeg FAB30 Top Freezer Refrigerator
Hi, we just defrost our Smeg Freezer FAB30 and followed the instructions on the website. It seems now that the fridge doesn't restart !!! Help ! What do we do ?
Jul 23, 2011 | Smeg FC40RX Bottom Freezer Refrigerator
My fridge freezer fc36rx smeg seems to not be working correctly, the top fridge is not getting cold but freezer ok, Please help
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 12, 2010 | Smeg Refrigerators
The fridge is not cold enough although the freezer seems to work
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2010 | Smeg FAB32 Bottom Freezer Refrigerator
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
88 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Mike
Jorgie Navito
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
