Question about Casio Office Equipment & Supplies
Set time on casio HR-750RC - Casio Office Equipment & Supplies
Posted by Rodney Treusdell on
4 Related Answers
Anonymous
SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
Posted on Feb 11, 2008
Anonymous
SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Posted on Feb 25, 2008
Anonymous
SOURCE: how to set time Casio W-89H two button watch
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Posted on Sep 21, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Changing from 12 hr to 24 hr on a Casio Data Bank 150
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please ...
Posted on Apr 02, 2010
We hit a button on Casio HR-170RC and now it keeps rounding up. How do we stop this?
It is the slide switch for decimal places. You needs to be set to 2 places.
Slide Switch ' Printing Calculators ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > Printing Calculators
Q1: What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for? (HR-8 series); A1: The HR-8 series have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4]. The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F ... Missing: 170rc
HR-170RC ' Calculators ' Manuals ' CASIO
support.casio.com > Support > Manuals > Calculators ·This page might be unreadable or wrongly displayed depending on your browser, OS version, and settings. In this case, please try with different browser (Chrome, Firefox, etc.) ·We recommend you to download the large PDF files from this site and view them off-line. [ To download a file ] 1.Align your mouse pointer with the ... Missing: rounding
[PDF]HR-170RC HR-200RC - Support - Casio
support.casio.com/en/manual/004/HR-170RC_200RC_WA_EN.pdf - Translate this page
Mar 15, 2017 - Back-up Battery. Your calculator comes with a single built-in CR2032 lithium battery that provides power to retain values stored in memory when you leave the calculator without power (AC ... Weight: HR-170RC: 570 g (20.1 oz) including batteries ..... performed with values as input, and the result is rounded.
Slide Switch ' General Calculator ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > General Calculator Q1: What is the use of the Slide Switch? A1: F: Floating Decimal CUT: Values are cut off to the number of decimal places specified by the current Decimal Place Selector setting. UP: Values are rounded up to the number of decimal places specified by the current Decimal Place Selector setting 5/4: Values are rounded off (0,1 ...Missing: 170rc
Mar 01, 2018 | Casio Office Equipment & Supplies
Set time format from 12 hr to 24 hr for casio LA670W
Was this problem answered? If yes, can somebody tell me how. My Casio LA670W is in 24hr format and I want it back on 12hr format. My watch have 3 buttons only. Mode, Start-Stop and Timer
Nov 22, 2013 | Casio LA670W Digital Ladies Watch LA-670WA...
Need to change the vat rate on casio hr-150tec calculator
I have a j-120 Casio, and the following worked on that:
Press and hold the 'rate set%' button (next to "Tax-" button).
The currently held rate will display.
Type in 17.5, then hold down the 'rate set' button again.
Voila!
Sep 09, 2010 | Casio HR-150TER Calculator
My Oceanus watch model no. 4749 stays 1/2 hr slow. I manually reset it to the correct time and it resets itself to 1/2 hr slow. I have it set at central time
You can get manual information from the Oceanus web site (NOT casio strangely enough!).
Insert "www.oceanus-us.com/" into your search engine
Select "support", then "Manual information"
Enter your model number and download the information. There are instructions on choice of home city and further adjustments if it still is not correct after initial setting up.
Jan 16, 2010 | Casio OC500 Oceanus watch
How to set time Casio W-89H two button watch
Jul 17, 2009 | Casio Watches
How to change the tax calculation from 5% to 6.8%
Hold down the % [SET] key until it blinks > press tax+ > type in the tax rate you want (ie. 8.75) . press and hold down % [SET] key until it blinks.
Aug 08, 2008 | Casio HR-8TMPlus Calculator
Casio calculator HR 100 Tm
Printing models (except HR-8TE):
1. Have calculator in “print” mode
2. Press [CA]
3. Hold [SET/%] key for about 5 seconds
4. Input the tax rate
5. Press [TAX+]
6. Press [SET/%]
Mar 12, 2008 | Casio HR-150TMPlus Calculator
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
77 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
