Question about Samsung Office Equipment & Supplies
It's not a solid line although it's perfectly straight- kind of looks like an airplane's contrails. This printer is about 10 years old
SOURCE: Lines along edge of paper
If the problem re-appears and updating the firmware (from office.xerox.com) does not help you are most likely looking at a replacement processor board.
Posted on Jul 28, 2008
SOURCE: Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Posted on Mar 02, 2009
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Posted on Apr 11, 2009
SOURCE: Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Posted on Sep 23, 2009
SOURCE: Horizontal lines appear every 4 inches on each
User manual page 6.17 says:
Horizontal streaks indicate improperly installed or defective toner cartridge. Try re-installing the cartridge.
http://downloadcenter.samsung.com/content/UM/200607/20060712143739406_ML-1710_English.pdf
Posted on Nov 28, 2009
Jun 18, 2010 | Samsung ML 1710 Laser Printer
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
Mar 06, 2010 | Samsung ML 1710 Laser Printer
Feb 05, 2010 | Samsung ML 1710 Laser Printer
Nov 28, 2009 | Samsung ML 1710 Laser Printer
Jun 12, 2009 | Samsung ML 1710 Laser Printer
Apr 28, 2009 | Samsung ML 1710 Laser Printer
Mar 18, 2008 | Samsung ML 1710 Laser Printer
Jan 22, 2008 | Samsung ML 1610 Laser Printer
23 people viewed this question
