The porthole of a Aristotle Aqualtis Washing machine won’t open. I have never used one before. The display panel show’s no End’ can you advise please?
Posted by Chris Lodge on
5 Related Answers
Anonymous
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
Anonymous
  • 15 Answers
SOURCE: Aqualtis washing machine door locked, need quick release?
yes there is a quick release
the door lock have 3 wires u should connect 2 of them together the first one and the third
but its dangerous if there is kids cause u will b able to open the door while its on
Posted on Jun 05, 2009
jan mczeal
Jan McZeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
david_davemo
  • 880 Answers
SOURCE: I have an 03 error displayed on a Bosch WFK 2801
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Posted on Dec 01, 2009
Prakash R
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
How can i find a porthole?
Please supply the machine's model number.
Aug 12, 2014 | LG Washing Machines
Ariston aqualtis aqlf9d
PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
Jan 04, 2014 | Washing Machines
Says F5 on display, wont empty.
just had F5 blockage warning on hotpoint aqualtis. Removed front panel on the bottom and unscrewed filter, cleaned and replaced. checked all outlet pipe was clear. Laid washing machine on to its back and removed black pipe from pump and checked and finally removed the other end of the pipe that joins to the drum. large ball acts a valve and a missing sock was found in the drum end! replaced all parts and washing machine works a treat! before the f5 warning the machine leaked from the door on a couple of occasions, no problem since and may have been a build up of water finding its only way out.
Jul 12, 2010 | Hotpoint Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
My Hotpoint Aqualtis washing machine keeps getting stuck towards the end of its cycle. It shows a F-05 on the digital display. Previously I was able to get the washing machine to finish by putting it on...
Jul 08, 2008 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
