Speakercraft DBB12100 12 channel audio Amplifier, Circuit problem causes protection light for 2 or more channels to come on after unit is on for 1/2 hour. Eliminated speakers & wiring as problem. I suspect the problem is in the power supply
Sounds like its a problem with over heating. open unit clean out all dust and dust bunnies wich compressed air. check that all fans are opperating. (fans on 6x100 amp units or thermal controled). If amp goes into protection prior to fans turning, there is your answer. the @ power supplies will have a green light on the output side. if the light in on power supply is good. or you can check that the output voltage is at 48Vdc on both units.
