Question about Poulan Garden
Poulan Wild Thing acts like it is trying to fire on the wrong stroke. The saw jerks the starter rope out of your hand. Is it a timing issue?
Is there a problem with the start rope? Actually I have two saws with the same problem.
Posted by Jim Barnett on
Kerry Cunningham
    Habit-Forming:
    New Friend:
  • 66 Answers
CHECK THE BELL CLUTCH , MAY BE HANGING UP AND NOT DISENGAGING !!!
Posted on Oct 29, 2019
1 Related Answer
Anonymous
  • 583 Answers
SOURCE: poulan wild thing chain saw rope came off
by the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Posted on Jul 25, 2009
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Where is closest repair shop to Gibson Island, MD 21056
Go to the Poulan service locator site at www.poulanpro.com/service-locator/ and put your location in the search box to find close service centers.
May 10, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The sprocket that runs the chain. Some teeth broke off. Need part and is it easy to replace
http://www.jackssmallengines.com/sprockets_poulan.cfm
Pull the sparkplug and turn engine till the piston is at the bottom of it's stroke then push some rope into the sparkplug hole so that when the crankshaft turns the piston will bottom out against the rope and stop turning. The sprocket is left handed threads. Just turn it off of the crankshaft and replace.
Nov 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
This is my second wild thing. I wore the first
Hello Ms Weem:
Will the starter cover from your first Wild Thing fit?
Have you looked at the starter cover on a different new Wild Thing (demo)? Is it like yours?
Are you releasing the starter rope with it extended?
Yours is the first problem of this type I've heard for your saw. There is no pulley guide or starter rope thimble I'm aware of. I'd think a small nylon or teflon bushing for the starter rope could be fabricated by a machine shop but it would be at your expense. HTH
Lou
Oct 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing chain saw rope came off
Jul 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull start on my wild thing keeps jamming
you can not pull the starter rope out to full length. Just short rapid jerks. everyone has this problem
Jan 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
113 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
