Question about Locks & Locksmithing
I have list my user Manuel and need to reprogram my Facto keypad lock. Help!!
Posted by Lynda Unterthiner on
2 Related Answers
VtToolMan
Mark
  • 704 Answers
SOURCE: new combination
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you might have to reset the lock prior to entering in your master code and other user codes, etc.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
Anonymous
  • 236 Answers
SOURCE: need to reprogram door lock keypad on 2005 ford
you'll need a scan tool. so you'll need to go to your local ford dealership or a locksmith.
Posted on Dec 31, 2009
Wher can i get program manual for facto electroni deadbolt
Log onto the manufacturers website and you should be able to find the user manual for download or on screen viewing.
You will need to know your specific lock in order to find the correct manual.
Jan 08, 2015 | Deadbolt Locks & Locksmithing
How do I program my rona facto lock
For Facto, remove the screw on the inside of the door on the door lock to get to the inner portion where you program
NB : in order to change the lock code, the chime feature has to be on (3rd little button on right bottom) or it will not change.
Make sure the chime is on.
Press the program button once and when it beeps, change the code on the outside keypad and press lock. (I suggest you test it before actually closing the door by hitting the lock button. The lock barrel should come out, as if you had locked the door. Hit the lock button on the keypad and key in the new number. The barrel should return inside as if you had opened the door. If not, it did not program the new number. Try programming again.).
Press the program button twice to change the second code and when it beeps, change the code on the outside keypad and press the lock. (Again, I suggest you test)
Apr 30, 2014 | Locks & Locksmithing
I have lost my pc for my schlage door lock. How do I fix that?
No problem!
A quick note: The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock, which i noted above. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Also, you will find "Keypad Programming Guide", etc. links which are PDF type files, giving you a "picture" of the print instructions.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck,and please provide feedback if this helps!
Oct 03, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
I have a schlage camelot leverset and i need to change the code. its a 4 digit code...How do i do this? thanks
No problem!
Aug 17, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
I want to change the code on our lock and I dont have a manual. Can you help me?
Reprogramming FE 375:
This link will take you to the page you need, to get started:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Jul 10, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I need to change the combo for my fe595 and dont know how. the serial number is 715739 andthe user codes are: A 6152 and B 1514. How do I reprogram the combination?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
Feb 06, 2011 | Schlage Electronic Lock FE595 Plymouth or...
I have a 4 digit schlage keyless lock and want to reprogram it
There's a video for reprogramming it.
Dec 20, 2010 | Schlage Locks & Locksmithing
What all can I do with my keyless entry keypad?
you will need the manuel to put your own code into the key pad. than you will be able to lock and unlock the doors.
Mar 22, 2009 | 2005 Ford Expedition
Locks & Locksmithing Logo
121 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
