Question about Furniture
Franklin chef FWC100 wine cooler is not cooling
I unplugged the unit to reset. Found water in the drip pans emptied cleaned and replugged the unit. The right side is at 62 the left side remains at 68. Both sides are set at 55. Lights and fan s are working.
Posted by Robert on
JBR Technical services
    Passionate:
    Visited the website for 10 consecutive days.
  • 94 Answers
Have you cleaned the coils? They have a coil brush or you can use a spray bottle with hot water to remove dust and debris.
Posted on Dec 14, 2019
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: 8 bottle wine cooler unit won't cool
First, see if the fan is actually blowing anything out of it. YOu may have an obstruction. If not that...Generally, there are three reasons that you won't get cooling:
  • The condenser radiating fins on the unit are dirty which won't allow cooling air flow to liquify refrigerant. Clean them.
  • The unit is frozen up inside because of excessive humidity. Defrost the unit by leaving it off and open for a day.
  • The unit is low on refrigerant. Check this by leaving the unit off for one hour. Locate the pipes coming out of the compressor. Turn the unit on. If the larger pipe stays frosted up for more than 15 minutes, you need to get the unit charged.
Posted on Jan 04, 2009
Anonymous
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: dual zone wine cooler left
Please can you give the model number of your Danby refrigerator
Thank You
Posted on Oct 14, 2010
Anonymous
  • 1478 Answers
SOURCE: Both zones of the wine
Check the thermostat for temperature setting. Also check the condenser coils and clean them if found clogged with dust. Unplug the wine cooler and wait for a couple of hours before plugging it again. If you can hear it running or whining, perhaps the compressor is being overheated. Test various components such as temperature control knob, evaporator fan, defrost timer, compressor relay, overload protector and the compressor motor.
Take care.
Posted on Oct 22, 2010
rayjor
  • 3 Answers
SOURCE: Franklin Chef FCW - too much humidity
Mine, too, and also mold. I put clorox in the bottom for the mold.
Posted on Dec 05, 2010
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Doesn't cool
You have troubleshot this thing well. You may have a capacitor problem or starter problem. It will not be design let the unit come on. This is all to protect the expensive compressor.
Feb 03, 2013 | Franklin FWC100 Wine Cooler
The alarm in our Franklin Chef model FWC100 wine cooler keeps going off even though everything stays cool so we want to know how to turn off the alarm or cut the wire to the alarm. Thanks.
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
Jul 29, 2011 | Franklin FWC100 Wine Cooler
I Have a Magic Chef MCWC44DZ and it is reading 82 for both zones. When i try to set it back to the normal temps it just locks up and goes back to 82
try to reset your unit unplug it then after a several minutes plug it on then observe unit. check your condensing unit the fan motor if working smoothly or clean your condenser possible dusty. use pressurized water. adjust your thermostat setting.then observe it.
Mar 10, 2011 | Magic Chef MCWC44DZ Wine Cooler
Oct 31, 2009 | Refrigerators
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Replacement Parts
Would suggest you try a distributor for this cabinet as sometimes they have more leeway with the supplier. Looking through sites would suggest someone like BeverageFactoy.com may have a route to the spares youre after. Hope this helps.
Feb 08, 2008 | Franklin FWC100 Wine Cooler
Furniture Logo
221 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
