Question about Refrigerators
Red light coming on when i open door of my Fisher&Packel fridge freezer
Posted by john jennings on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Posted on Jan 08, 2008
Anonymous
  • 3 Answers
SOURCE: Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Posted on Feb 27, 2009
Anonymous
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 28, 2009
Anonymous
SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Posted on Jul 08, 2010
Fisher and packel active smart is beeping when door is closed and is now defrosting the freezer and freezing foods at back of fridge... How do I fix this?
It is evidently not out of refrigerant then. It will beep at you to advise that it was set to bottle chill and time is up, or that either door was left a bit open.
Also make sure the slot at the upper back of the fridge compartment is not blocked with items. That has to be left clear as it is where the cold air comes out to circulate.
Try turning it off for 30 min and then back on.
If the condition persists you will have to call F&P service. Take note of just when it beeps and the exact number of beeps. They may want to know this.
Dec 29, 2016 | Fisher Refrigerators
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fridge Freezer E402B not functioning properly.Solid red error light,with green light flashing up and dwn when push the = button.No air circulation to fridge,compressor seems to continious,also fridge
Natasha try this:
turn off the fridge's settings.
pull the power cord from the wall outlet
open the doors and keep them so for a few hours.
before these, take out the most perishable and keep in cool place.
after a few hours you may see a puddle of water under the fridge. clean the water and vaccum the fridge underneath and behind.
now reconnect power and set at recommended level. goodluck!
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Hi, I have fisher and paykel E522BLX bottom freezer fridge. It is making beeping sound sometimes when I open the door. It also has green light flashing on the control panel all the time. Both fridge and...
beeping when door is open is one of its features the flashing light means someone has tried to set something and not completed the selection just try pushing one of the buttonstill it stops
Jan 29, 2018 | Fisher and Paykel E522BLX Bottom Freezer...
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Dec 21, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
