Question about Panasonic Video Cameras
Can i connect an external microphone to my panasonic SDR-S45 video camera?
Posted by Farooq Moma on
5 Related Answers
Anonymous
SOURCE: Panasonic SDR-H18
You also have to plug it into the power source. They put it together with the charger. Get the charger and you will see that you can plug the AC adaptor cable in the other end. This allows you to power up when you are using the USB.
Posted on Dec 26, 2007
Anonymous
  • 763 Answers
SOURCE: transfer my video from panasonic sdr - h40
try to use USB to plug your device to your computer. make sure that you have an installed driver for your camcorder to recognize your device on your pc. all brand new camcorder came with an installation software cd. now your ready to transfer your video to your computer. use any movie maker application like ulead movie maker, nero movie maker or windows movie maker edit it and save it. burn it to your vcd or dvd burner to play on your dvd player. if you dont have a driver i will find one for you. hope that helps!
CHARCOIS
Posted on Jul 28, 2008
Anonymous
SOURCE: Video Cam Suite 1.0 does not work with Windows Vista 64 bit
Excuseme If I don't explain so clair, because I don't speak english well, but let me try that I did to solve this problem. First I installed a Virtual Machine(VMware Workstation 6.5.1) in miy Pc(64 bits) . Second, I installed a Windows Vista home basic(32 bits) or Windows XP Sp2 (32bits) on it., depending of what Operative sistem do you have in your real machine. And finally I could installed the Videocam suit in the Virtual Machine and everything was ok. I could transfer all my videos of the camera to the pc very easy The only inconvenient is that you need to transfer the videos downloaded of the virtual machine to the real machine with a flash memory or similar something.
Posted on Aug 25, 2009
supermorph
  • 17 Answers
SOURCE: Panasonic SDR-H40P Hard Disk Video Camera loses focus
Keep it still roughly 5-6 seconds in the same spot and it will re-focus
i had that once
Posted on Sep 16, 2009
Anonymous
  • 3 Answers
SOURCE: software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Posted on Jan 03, 2010
tip
Convert/Import, Edit Panasonic SDR MOD Files to Mac, iMovie, FCP
Panasonic SDR camcorder mainly contains SDR-H and SDR-S two series. Most Panasonic SDR series camcorders record videos in MOD MPEG-2 which is a standard definition video format, such as some popular Panasonic SDR camcorders: SDR-S26, SDR-S10, SDR-H60, etc. However, there are also some Panasonic SDR camcorders recording videos in AVCHD /MPEG-2 like Panasonic SDR-H86, SDR-S45, SDR-T56, etc.
To get more details of Panasonic SDR camcorders, you can check the list of most popular Panasonic SDR series camcorders as follows:
Panasonic SDR-H Series: SDR-H18, SDR-H40, SDR-H60, SDR-H80, SDR-H85, SDR-H81, SDR-H86, SDR-H200, SDR-H80S, SDR-H80K, SDR-H80A, SDR-H80R, etc.
Panasonic SDR-S Series: SDR-S10, SDR-S26, SDR-S50, SDR-S45, SDR-S150, SDR-S25A, SDR-S26K, SDR-S26R, SDR-S7K, SDR-S7A, SDR-S7R, etc.
Panasonic SDR-T and other Series: SDR-T50, SDR-T55, SDR-T51, SDR-T56, SDR-T50K, SDR-SW21S, SDR-SW21D, SDR-SW21G, SDR-SW20S, etc.
"I have a SDR H85 panasonic camcorder and can't seem to get the videos to download on my mac. Any suggestions?" ---from Yahoo Answers
Actually, for Mac users, you may have these similar problems when you want to import Panasonic SDR video to Mac, or edit these video in iMovie, or FCP, FCE. Because some Panasonic SDR series camcorder are not compatible with Mac, so you cannot directly import these camcorder videos to iMovie, Quicktime, or FCP . See here to know iMovie '09: Camcorder Support http://support.apple.com/kb/ht3290
Now, a professional Panasonic SDR Video Converter for Mac is specially designed to convert MOD(MPEG-2) to MOV, MP4, AVI, DV, H.264, 3GP, 3G2, M4V, WMV, MKV, etc on Mac. It supports converting MOD, TOD, AVCHD MTS/M2TS, etc to Mac, iMovie, Quicktime, iDVD, FCP, FCE, iPad, iPod, iPhone, Blackberry, PSP, and other popular mobile phones. This Mac MOD Video Converter can also help you extract audio from your Panasonic SDR videos to MP3, MKA, WAV, M4A, AC3, OGG, AAC, WMA, etc.
Instruction for you to convert Panasonic SDR video to Mac, iMovie, FCP, etc step by step
Step1: Install and Launch MOD Converter for Mac
Step2: Add Panasonic SDR Video on Mac
Click "Add File" to upload your chosen Panasonic SDR video to Mac MOD Video Converter after you launched it.
Step3: Set Output Video Format for Mac, iMovie, Quicktime
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step4: Convert Panasonic SDR Video to Mac
Press the "Start" button to convert Panasonic SDR MOD/MPEG-2 files for Mac, iMovie, Quicktime, FCP, etc. After conversion finished, you can edit converted Panasonic SDR videos with iMovie, FCP, FCE, iDVD, etc.
More details: If you want to convert Panasonic SDR AVCHD/MPEG-2 files to Mac, you can click here to get more info of AVCHD Converter for Mac.
Related: How to get video off camcorder to Mac OS?
How to convert AVCHD m2ts/mts/ts files to MP4, MOV, DV, etc on Mac?
on Nov 05, 2010 • Computers & Internet
tip
Panasonic SDR-S26 Manual Download
Download Panasonic SDR-S26 SD Video Camera Manual
Have you misplaced your Panasonic SDR-S26 SD Video Camera Users Manual?
Would you like a digital, searchable, pdf version of the Panasonic SDR-S26 SD Video Camera Users Guide?
Follow this link (& click FREE) to download a pdf version of the Panasonic SDR-S26 SD Video Camera Users documentation.
I hope that helps.
on May 06, 2010 • Video Cameras
Where can I buy a replacement charging lead for an SDR-S45 Camcorder?
https://panasonic.ca/PCS/OperatingInstructions/SDRS50,%20SDRT50,%20SDRT55,%20SDRH85%20E.pdf Look on page 8. The part numbers for the cable you need is there. Use that information to locate a replacement.
I have an SDR-S45 Panasonic camcorder. I've lost the charging lead. How can I replace it?
take it to an electronic retailer ( JAYCAR or the like ) and identify the connections
they have a range of adaptors and chargers
go e bay and search for-- charger and cord for ( your camcorder)
tip
I hope that helps.
Panasonic camcorder SDR S45
You may download a copy of the manual here.
2helpful
1helpful
Download camcorder manuel
Video Cameras Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
