Question about The Audio Players & Recorders
Will lp12 hinges fit the recess on an SL-d303 turntable as the tabs have snapped off on my lid. So I need to find an alternative.
Posted by phil carpenter on
5 Related Answers
Anonymous
  • 515 Answers
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
Posted on Apr 30, 2008
Anonymous
  • 515 Answers
SOURCE: technics SL-L92 directdrive automatic turntable (needle fixed in lid)
Not sure what could have happened here. Maybe a wire came loose - doubtful, but possible. You will have to open her up to see if there is anything unusual inside. Or, you'll need to take it to a service center for a diagnosis.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Posted on Jul 23, 2008
K W
  • 509 Answers
SOURCE: how to fit a new alternator belt
If it's just a single belt and you know where the belt tightener is you can do it yourself. Just loosen the tightener up, put the belt on and tighten belt so there is about 1/2" deflection when you push on the belt in the center of the pulleys, then tighten the bolts.
Posted on Jan 06, 2010
rc
  • 417 Answers
SOURCE: I need a replacement lid/dust cover for my
There are 2 complete turntables up for auction on Ebay. One is at 4.99, and the other is at 9.99. Just do a search.
Posted on Apr 28, 2010
caroldon
  • 17130 Answers
SOURCE: Hinge has broken on turntable
Only if you search around old repair shops, or maybe there can be some second hand spare shops in some district where a good selection of old electronics can be sourced.
Other wise you can get this mended using most modern techniques. if the crak is small new type of glue with reinforcement can do the job. alternatively you can get the broken part made to wedge along with presision with the same material , the help of a good tool shop can be handy.
Posted on Sep 02, 2010
Is the dust cover on the Technics SL-B101 , the same as the Technics Sl- D303?
Charles,
It took me about an hour to find this info for you. Problem is that you'd be taking someone's word for it. The answer came from a turntable forum where another person asked what other dust covers fit the pictured turntable (model SL-B303) Several people responded and if you click on this link:
http://audiokarma.org/forums/index.php?threads/technics-sl-b303-dustcover-hinges.348163/ , look at the bottom right hand corner of every response on that page.(they are numbered) and you'll see that #1 has the question about the cover for the SL-B303. Scroll down to response #6.
This person says that the SL-B101 and the SL-D303 use the same cover.
Where did he get his info from? It's a risk but if you find another person that says the same thing, chances are it's the right answer. Wish TECHNICS had some sort of official release so that everyone could see what covers fit which turntables.
Good luck
Jun 22, 2017 | Technics Audio Players & Recorders
I've just bought a new lid for my 1200 Technics turntable, but can't work out how to attach it and don't want to break anything trying first.
All the new one dont have the hinges any more....The just ahve the rubber feet on the corners and it will just sit there...The older ones with the hinges will have a part sticking up..Slide the male part from the tables hinge into the female part of the hinge on the cover.
Oct 16, 2009 | Technics SL-1210 Turntable
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
- DJ PRO LAB
www.DJPROLAB.com
Apr 08, 2008 | Technics SL-1200 Turntable
Technics sl 1210 mk5 g's
Instructions for putting the lids can be found here:
http://www.1200s.com/Service/Tech/faq.html
FYI, the dust covers on this model do not come with hinges. So, you'll have to purchase them separately.
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 29, 2008 | Technics SL-1210M5G Turntable
Sl-1210mk5g's
It should be fairly obvious. The only thing I can think of it that the hinges are missing (these slot in to both the lids and the turntable and are easily lost if someone has been using them with the lids off).
If they are missing, it certainly would make it difficult to figure out!
Matt
55 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
Larry Stiles
Larry Stiles
JOHN TOPLISS
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
