Question about Ricoh Office Equipment & Supplies
Why my ricoh get paper in Fuser - Ricoh Office Equipment & Supplies
1 Related Answer
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: I have replaced the fuser unit and fuser oil, and
One or more of the drum units or the transfer belt cleaning blade is bad. Only way to tell is to remove each drum and check the surface for the toner "streaks". You can also pull out the transfer belt and check the surface for the streaks. It will be one or the other. Now if you streaks are of a particular color then that points more to the drum of that color.
Posted on Jan 07, 2010
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Jan 02, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Ricoh 1018 Fuser finger pickups malfunction. I acquired one upper pickup finger for the fuser drum/roller and two new springs. All were missing after a jamb. The new pieces have been installed and the...
Hello!
Assuming that the fuser "fingers" are well assembled you need to see if the fit is ok. It happenes all the time that this fit is broken and can not holds the "fingers"
Sep 10, 2011 | Ricoh Aficio 1013F Copier
We have a Ricoh Aficio MP c5000 and I'm trying to duplex copy in color and it keeps jamming right at (what I assume is) the fuser. I can copy in black and white duplex but not color. It's almost like it...
Fuser could be wearing. copying in color creates a thicker layer of toner on the paper which in turn creates more friction within the fuser. Make sure the copier is set to thick paper if in fact you are using thicker than 20 pound paper.
Jan 08, 2010 | Ricoh Office Equipment & Supplies
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
A lot of problem with RICOH Aficio SP c210
hi,try to check internal fuser section b/c there are a lot of parts in fuser for example:-heat roll,pressure roll & web roll especially if the web is damage there is the problem try to replace it.
another but easy solution clear piece of paper in fuser.
May 13, 2009 | Ricoh Office Equipment & Supplies
Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Jun 26, 2008 | Ricoh FAX5000L Plain Paper Laser
Corners folding while copying
if it is just folding the paper back without pressing it, then its a problem in the fuser. Paper sticking to long to the upper fuser roller and catching either a pick off finger or a mylar on the exit of the fuser.
Hope that helps...
Jun 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
