Question about Hardware & Accessories
Bought Athena glass panel heater 05225743, how to set timer/program?
1 Related Answer
Anonymous
SOURCE: 1000w athena glass panel heater, how to set
Recently bought the Athena glass panel heater from B&Q but there were no instructions. Easy enough to set time but how do you set the timer for coming on in the morning and then again in the evening?
Posted on Mar 01, 2011
Can you set different programs for the heating and the hot water?
Yes, most heat-water heater timers can be set for different schedule.
Add a comment and include the timer brand and number and I will look up manual if available.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#towerchron
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 04, 2015 | Hardware & Accessories
Where can I buy parts for Athena 1000w glass panel heater
Have you tried mfg website?? Or a product sales point.
Nov 08, 2014 | Heating & Cooling
1000w athena glass panel heater, how to set timer/program?
Dec 07, 2010 | Heating & Cooling
How to program timer?
Diagram showing timer tabs being pushed in or out to set programs:
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
Grundfos illustrated installation guide
http://waterheatertimer.org/pdf/Grundfos-L-UP-TL-043-install-photos.pdf
Rotate programming ring clockwise until current time lines up with arrowhead on inner dial.
Current time must be reset after power outage.
Tabs located around programming ring control timer functions.
Each tab represents 15 minutes.
Tabs push in or out using a pen.
Tabs out = grundfos ON
Tabs in = grundfos OFF
Set manual switch to TIMER and timer program operates pump
Set manual switch to ON or OFF to override timer program
Dec 04, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Water does come through to the icemaker so there is no ice. We just replaced the filter unfortunately we bought the refrigerator 6 tears ago this December. I am lost without ice. Please help!!!!!!!!!
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension. 2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only. 3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost. 4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad. 5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!! 6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator. 7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install. Follow these steps and this will solve your problem. Take care......
Oct 31, 2010 | Refrigerators
The freezer is running all the time and no ice. The freezer is on the bottom and the ice is created in the bottom freezer. We bought the refrig. in 2001.
Take care....
Oct 04, 2010 | Amana ABB1927DE Bottom Freezer...
Hardware & Accessories Logo
126 people viewed this question
Top Hardware & Accessories Experts
Tom Chichester
ray gallant
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
