Question about Refrigerators
I have a Fisher and pykel fridge with the f20 code coming up but I have checked both hinge wires and they are still intact could it be that the wire inside the insulation is broken?
Posted by Ben Hawkins on
5 Related Answers
retrorecycle
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
Anonymous
SOURCE: Model E372b Fisher & Pykel - Beeps with Fridge Door closed periodically-Higest shelves warm lower down freezes things
First I would like to say thanks for all the information on the Fisher-Paykel active smart fridge freezer problems. This was a lot more useful than their customer support help line… After a week of hanging on for ten minutes without any answer I had a look on the net and found your site with descriptions of similar problems so I decided to investigate further
I have a Fisher Paykel fridge freezer (model 402B in the UK) about three years old. Although it didn’t seem to be as cold as normal, the first sign of a serious problem was when it started making a rattling or knocking noise from the freezer compartment. Looking inside it was obviously iced up solid and the noise was probably the fan catching the ice. So first thing I decided to try was a days de icing after which everything seemed ok except the green indicator light was now flashing about once every second.
Two weeks later it was badly iced up again so the problem was still there. At first I suspected the fans (which I could never see actually working). I disconnected one and tried it with a 6v torch battery and it spun ok. It was then I realised what was happening - the fans cut out whenever the door is opened so they are always stopped if you look inside.
A closer look at the aluminium heat exchanger(behind the plastic panel at the back of the freezer section) showed there was some kind of heater element clipped along the bottom with feed wires at either side. Obviousely part of the automatic de icing systems. It’s a bit tricky but there an electrical connector plug at the top and disconnecting this enables you to unclip the element and remove it (except that in this case one wire had been trapped at the wrong side of the coolant pipes when they had been fitted so it had to be snipped to get it out). Once out a circuit test showed there was no circuit through the element. So cutting into the two shrouded connections at each end of the element revealed some little components inside which I now know are “Thermal fuses”. One of these had “Blown”. There was a number on the side: - DF 72S which Google revealed is a thermal fuse set at 72 degrees. Although these are listed as spares in all sorts of places non was convenient to the UK. So I found a similar component at Maplins Electronics (R14) set at 92 degrees for just 69p! The reasoning being that the other thermal DF 72S fuse was still ok and the slightly higher use temp at the other end would still blow before anything melted!
By the way you cannot solder these things in so its best to use miniature screwed “block” connectors plus a good covering with insulation tape.
After putting it all back together its now been working for a month and no ice build up… The green light did still flash for a while but went out once the temperature dropped too normal freezing level.
Total cost of replacement parts was under £1 but it took a bit of time find the problem.
Posted on May 12, 2008
Anonymous
  • 27 Answers
SOURCE: Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Posted on Jul 15, 2008
Michial Gueffroy
  • 1140 Answers
SOURCE: SHure SM57 mcorphone not working -wires disconnected
The wire coming from the switch if it has one will go to pin 2 as it is hot(+ve). Pin 3 is cold (-ve) and pin 1 is gound/shield which will make contact when the XLR connector is mounted back in the mike secured with the set screw. There should be a small hole in the side of the base of the mike that the set screw lines up with. Usind the correct size of flat bladed screw driver, back this screw out counter clockwise to secure the connector. If that is wrong, get back to me and i will hunt up my Shure wiring diagrams. If pin 2 and 3 are backwards the mike will be out of phase. Hope this helps.
Posted on Apr 29, 2009
Anonymous
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
My fisher and pykel fridge was in storage for 18 mths now the fridge door will not seal it is about 20 years old
if he fridge is working , get a new door seal fitted
there are mobile seal a fridge operators that will have the correct seal profile and can make a seal for the door in your house
Aug 15, 2018 | Refrigerators
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
When opening the fridge doors the alarm sounds on the screen is a number F20
You failed to say the make or model of your refrigerator.. Is it a Fisher Paykel? F20 and beeping typically means that you have a broken wire somewhere between the mainboard and the controls in the door. It could be as simple as a loose harness under the hinge cover (at the top of the door) that just needs to be more firmly plugged in.
Jan 27, 2018 | Refrigerators
I have a fisher pykel washing machine model WL80T65CW1 and it keeps coming up with a code 245
That is a water draining problem. From Sears: "Remove any clogs from the house drain for the washer. Remove any clogs or kinks from the washer drain hose. Unplug the washer and check the drain pump for a clog. If the drain pump is defective, replace it."
May 12, 2015 | Fisher Washing Machines
What is the resistance of heater element of a fisher & pykel fridge E402BRE
normal resisatnce is about 12000 ohms but why would u need the resistance when all u need to know is if its open or close circuit normally? other words OHMS OR NO OHMS INFINITY
Feb 01, 2015 | Fisher Refrigerators
Fisher paykel French door fridge shows F20 error everylme the door is opened - it beeps
F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires together with a auto12v type connecter or solder it and use shrink tube. Switch the fridge back on and hay presto, you can fill your fridge to the max 3 times over with the money you just saved. It will happen again as the wiring loom they fit is well and not flexible. Use silicone insulated wire from J-car or similar and replace from the plug and reconnect inside the door where the wires don\'t bend. Hope this helps you.
Feb 15, 2013 | Fisher and Paykel Refrigerators
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Jun 19, 2010 | Fisher and Paykel (IWL12)
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
