Question about Toro Garden
Toro CCR 2450 snowblower won't start.
I verified I have a spark, put fresh gas/oil mixture, I removed and cleaned the carb and replaced the carb gasket while I was at it. The primer is pushing gas into the carb. The engine just will not start. Do you have any ideas?
  • Toro Master
  • 2,015 Answers
Try a short burst of starter fluid into the carburetor and promptly pull starter. If it runs for a couple seconds and quits then the carburetor is not delivering fuel.
If it doesnt run on starter fluid then either flooded, insufficient spark, or poor compression / crankcase leak.
Posted on Oct 27, 2019
Testimonial: "Thanks for the advice. I will try the starter fluid first. Like l mentioned, I unhooked the spark plug and can see a faint spark when I pull the cord. I am not sure how I would check for an insufficient spark like you mention. Also I don’t know how to test for low compression."
Anonymous
SOURCE:
Anonymous
  • 117 Answers
SOURCE: 6hp toro snowblower. cleaned carb, reinstalled all
The diaphram in the carb is not working or there is an air leak somewhere in the intake or the float may not be working or the needle inside the carb may not be working or it's sticking.
Posted on Dec 19, 2009
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
odiebugs
odiebugs
  • 949 Answers
SOURCE: Hello, I have a Toro snowblower Model ccr 2450.
Remove the starter, then check the teeth, if the teeth
are ok, then the throwout Bering is bad, this is the part than pushes out the teeth so it contacts the
flywheel. The parts you need, teeth ,spring, throwout,
show as a kit, but you must buy them from a toro dealer, You need to have your serial #, because the parts are listed by different serial #'s. Now most times you would have to buy the whole starter, but it looks like you can get the kit. If the teeth are bad then the throwout is ok, but you still need the kit to fix your problem.
Posted on Feb 14, 2010
daneinwv
Dane Beckett
  • 124 Answers
SOURCE: what is the gas/oil mix for a Toro CCR 2450?
Hi my names Dane, and I'm going to help you.
The mix on the toro CCR 2450 is 50:1 I don't know if you;re having any more problems, but I wanted to include this link for you to check out. I'll let you judge.. Thanks! Dane
http://mattfleming.com/node/45
Posted on Dec 12, 2010
bryan st
  • 122 Answers
SOURCE: Toro CCR 2450, Common starting problems? Fresh
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
Posted on Feb 02, 2011
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
Idles ok revs up and stalls out
Aug 13, 2013 | Poulan Garden
Oil in the gas tank
Not a big deal. Im assuming this is a 4-stroke push mower and not a leaf blower.
Remove the air box cover, air filter, and air box back plate. Careful there is a gasket on the back of the backplate that if damaged the primer bulb wont work, part # 272653. Remove the fuel line from the carb and drain the tank. Using a 1/2 inch wrench remove the bowl nut from the float bowl on the carb, hold the bowl to the carb as to not break the gasket seal, drain the bowl and replace the bowl nut. If you tried to run the unit and oil is in the cylinder remove the spark plug ( clean the spark plug) and spray some carb cleaner in the hole and pull the starter rope several times to purge the cylinder. Reinstall the spark plug, reattatch the fuel line, install the air box back plate ( leave the air filter and cover off for now), add fresh fuel.
Take unit outside and start, you may need to give it a shot of carb cleaner in the throat of the carb to help it start. It may smoke, it may blow oil out the muffler. Let it run until it quits smoking ( usually around 5 minutes) . Shut it off and complete assembly. It should be fine.
Oct 05, 2012 | Toro Lawn Mower With Toro Power Tools
Forgot to drain the gas last fall and found it had small amount of water in the tank. Drained it out and cleaned the fuel filter, cleaned the carb out and now it starts, but runs only if the choke is on.
I would recommend replacing the fuel filter and spark plug. If this is a 2-cycle engine be sure you are using fresh gas with the proper oil mixture. If your engine has a fuel primer bulb be sure to push it several times until you feel resistance before starting and make sure there are no fuel leaks. Failing that you may need to adjust the carb fuel mixture screws after the engine runs long enough to warm up (1-2 minutes). Check your owners manual for other troubleshooting procedures. Good luck.
May 24, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Won't prime, the only way i start it is to remove spark plug and put fuel in cyl. I have replaced the primer bulb and line, and the fuel mixture is correct, My next step was to buy a new carb?
try to keep it running on wd-40 after you get it started and sometimes it will clean-out the carbs varnish blockage,if not remove and clean or replace the carb
May 13, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Garden Logo
102 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
