How do I divide a fraction n my 30xiis calculator?
Posted by Alicia on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: fractions appear when I divide; not decimals
you can also go press the 'mode' button, and go down until you're at 'Exact/Approx' and choose '3: Approximate'
Posted on Sep 20, 2008
Anonymous
SOURCE: When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Posted on Dec 08, 2008
Anonymous
SOURCE: The calculator won't convert fractions into decimals
Are you using a ti-89? If so, check your mode settings and change Exact to Approximate.
Posted on Feb 09, 2009
Anonymous
  • 81 Answers
SOURCE: rounding function on my TI-30xIIs calculator, it won't turn off.
This function is FIX or FSE near the dot [.] or above it, so press [2nd] the the [FIX] where it located button [.] for example then the dot [.] him self: [2nd] [FIX] [.]
Rate me, thanks.
Posted on Jul 08, 2009
k24674
  • 8091 Answers
SOURCE: my calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
Posted on Sep 24, 2009
How to divide fractions using calculators?
To divide fractions proceed as you usually do with any number. Just make sure to enclose each fraction in parentheses. You may want to remember a simple rule: To divide a fraction by another, multiply the first one by the reciprocal of the other:
(a/b)/(c/d)=(ad/bc)
Sep 08, 2014 | Office Equipment & Supplies
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
How to divide mixed numbers?
Probably the simplest is to convert both numbers to improper fractions then divide.
Some calculators can work with fractions. With one of those, simply enter the first mixed number, then divide by the other.
Aug 14, 2013 | Mathsoft Computers & Internet
My calc won't divide anymore just gives me fractions. what did i do?
To change a result from Fraction/radical to a decimal approximation, press the key marked S<>D. To completely prevent the display of fractions, change Input/output configuration.
Press SHIFT MODE to enter SetUp. Select LineIO
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
How to find G.C.F. on a TI-30xIIs calculator?
I don't think there's specific key for this but you can do it this way:
  1. Divide those 2 numbers for which you want to find gcf
  2. If you get result as decimal number press keys [2nd][PRB] to display it as fraction
  3. Also if fraction you get is in form a b/c (ex. 1 2/3) you have to convert it to form d/c (for 1 2/3 that would be 5/3)
  4. Greatest common factor is then 1st number divided by numerator (or 2nd number divided by denominator)
For example:
  • You want to find greatest common factor of 30 and 18.
  • You divide them: you should get 5/3 (after converting result to fraction of form d/c, as described in steps 2 and 3).
  • This means that 30/18=5/3=5x/3x (x is gcf here).
  • Now you know that x=30/5=18/3=6 so greatest common factor is 6.
I hope this helps :)
Sep 10, 2011 | Texas Instruments TI-30 XIIS Calculator
My TI-30XIIS calculator displays an arrow,an DEG, and a K always on my screen whenever i try to do simple multiplication. it says Syntax error and will not compute an answer.............
I had this problem also and just fixed it. I hit 2nd key...don't hold it, (it should say 2nd in the lower left corner across from the DEG) then click the K button (also the divide key). The arrow and DEG will remain, but do not affect simple math calculations. Hope this helps!
Feb 09, 2011 | Texas Instruments TI-30 XIIS Calculator
How do you convert decimals to fractions?
With the decimal value on the screen, press 2nd F<>D.
F<>D is on the PRB key, second row, second column.
Jul 02, 2010 | Texas Instruments TI-30 XIIS Calculator
Dividing fractions
Once a fraction is entered it can be submitted to all allowable operations, like any other number. So keep the fractions coming. The calculator will reduce them to their simplest expressions.
Hope it helps.
Apr 12, 2009 | Casio FX-300MS Calculator
Mixed fractions
When you get a fraction for he answer: shift-S<->D[a b/c<->d/c]
This way, you change it to a mixed fraction or improper fraction
Sep 14, 2008 | Casio FX-115ES Scientific Calculator
Dividing fractions
well I`am having a promblem with fractins and its hard for me to divid a fration
Jan 25, 2008 | Texas Instruments TI-30XA Calculator
55 people viewed this question
jasbo
jasbo
Marvin
Marvin
