Hi, when I try to open a playlist file using AIMP, I get this error code: CODE:2 (00000002). Any help would be appreciated!
Posted by John Hrabar on
5 Related Answers
Anonymous
SOURCE: Playlists on the MicroSD card?
I have found our solution I think. It works for me, but I don't know how it will handle Napster files. Give it a try though. It's called Sansa Playlister. I am using it now and it works perfectly and sees both the player and the SD card. The link is: http://hcware.110mb.com/sansa/. Give it a shot and let me know if it works for you as well.
Posted on Feb 14, 2008
Anonymous
  • 42 Answers
SOURCE: create a media player playlist
You will need to give me more information, Because I cant provide any codes without knowing your Programming language.
Plus what type of software you are using to complie your project?
Posted on Mar 05, 2008
Anonymous
SOURCE: playlist??
right click your playlist, add to sync list.
Posted on Mar 26, 2008
Anonymous
  • 14 Answers
SOURCE: Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Posted on Sep 16, 2008
Anonymous
SOURCE: Unable to open yahoo email : error message code 2
Hi Tech support,
I am unable to open yahoo mail from last couple of days. It gives an error message after logging in and no emails open.
pls help me
Posted on Oct 24, 2008
How do get all my songs to play random and not just some of them over and one,so i can listen to then ALL?mine just plays some songs over and over,then shuts off.i want it to play all of them randomly.not...
Since this is in the computer section i would assume you are using a computer or laptop to play music. You can download a program such as AIMP to give you the ability to create large playlists across multiple folders and hard drives.
Feb 04, 2018 | GPX MW252S - 4GB MP3/WMA Digital Audio...
I need to delete some music out of my recent added and delete the playlist and i dont know how
click start all programs accessories scroll to windows explorer open you should see all of your computers drives
navigate to the playlist select the music files you want to delete right click select delete
if you need more help with this post a reply
hope this helps you
Sep 15, 2011 | Computers & Internet
I have Windows 7 Home Premium desktop. When I try to back up to DVD the back up stops at 25% with error code Ox800703EE with the message "the volume for a file has been externally altered so that the...
That error is because the backup ID when it starts to back up becomes different as the DVD fills up.
I would backup to USB, faster and easier to use.
If you wish to backup to DVD use a backup utility like Norton Backup or Acronis etc. They can make an image file first and avoid this problem.
Dec 21, 2010 | Computers & Internet
Trying to burn a playlist from my itunes account and get 4261 error message, what does this mean?
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
Apr 01, 2010 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Error code 80029c4a quickbooks easystart 2010
This should help.. restart and then follow this..
To resolve this error, try restarting the computer that hosts the company file:
  1. Click the Microsoft Windows Start button and select Shut Down. The Shut Down window opens.
  2. Click the drop-down arrow and select Restart, and then click OK.
  3. Open Quickbooks and try to open the company file.
If the error continues, ensure that any firewall and/or antivirus software is configured to allow access to the QuickBooks company file and folder.
Jan 05, 2010 | Computers & Internet
Making playlists on my sony walkman mp3 player
OK so it is a little confusing on how to create a playlist, I am about to make your headaches go away on this issue.
1.Plug your mp3 player into your computer. 2.Go to my computer and open your mp3 player in windows. 3.go to your folder on your mp3 player that you have files folders etc.. that you would like to add to a playlist. 4.right click on folder and choose "create playlist" 5.Name your playlist.
thats it ! you should now have a playlist on your MP3 player, I hope this helps.
Jan 07, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Create a media player playlist
Mar 05, 2008 | Computers & Internet
Mp3 Player YP-U2 build error
I had this problem and I found the solution.
The problem is that you have a file, maybe in the half of your playlist, which is bugged or corrupted. Try to delete every single files and put them one by one to find out which file is bugged.
Feb 10, 2008 | Audio Players & Recorders
M250 does not recognize some songs in the playlist
Use Windows Media Player to do this, not winamp
Nov 03, 2007 | SanDisk Sansa m250 MP3 Player
69 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
