Question about The Audio Players & Recorders
My Berennis player won't play a whole song...it starts a song then goes to the next, then the next..i Have used this before with out it doing this...
Posted by Nancy LeForce on
5 Related Answers
crazycat506
SOURCE: xbox 360 playing music
plug it into the xbox and select an option on it that is `normal` it is probably on intro.
Posted on Jun 07, 2008
Anonymous
SOURCE: My MP3 player only plays the first 10seconds of a song.
maybe it's on intro mode, where it only plays the first ten seconds. enter the menu when a song's playing and change it to normal mode
Posted on Jul 21, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: MY SANSA WONT PLAY SONGS, IT SHOWS ARTIST BUT STUCK IN PAUSE
Some songs are in the wrong format, or your DB is corrupt. Either way:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Anonymous
SOURCE: Electro brand mp3 player(model mp3774) only plays 10 secs of song
I have the same 3774 mp3, what I did was took a nother mp38379 that worked, I download all the info to a dir in my labtop, then I put the mp3774 in and formated, then I uploaded the info from my mp338379 to the mp33774, the format is wma from mpe338379 is [wma] and the mp33774 came to file it now works
Posted on Apr 10, 2009
Anonymous
  • 96 Answers
SOURCE: my uncles mp3 only plays 10 seconds of a song each time it plays
Your Uncle's player is stuck in INTRO mode. To remedy this problem
1. Play a song
2. press the button on the side of the player
3. Select PLAY MODE
4. Choose NORMAL
Posted on Oct 24, 2009
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
My 256MB Personal MP3 Player will only play ten secounds & go on
First, it would have been helpful to know what is the model of the MP3 player, so answers can be specific. However, you seem to have accidently program it to play the intro of the songs. There should be a settings which enable you to change it back. Check for "A-B" it should be the symbol for the menu used to do that.
Aug 14, 2009 | Audio Players & Recorders
Sansa e270 next song play problem
if you are holding it down (all you are doing ff or rewind), but if you tap it will skip...plus you can also go to menu settings playback settings and change the skip / backward from seconds, mins and whole track...
hope this help
Jun 30, 2009 | SanDisk Sansa e270 MP3 Player
Song stops midway and moves on to next song
if there still new apple has an excelent return and repair program for factory defects.
Apr 15, 2009 | Apple iPod classic MP3 Player
Can't choose alarm song on iPod
The best way is to select the song you want to play is:
1: Select the song and start playing it using your iPod
2: Pause the song
3: Plug the iPod into the clock
Next time the alarm goes off it will use the song currently selected on the iPod. Hope this helps.
Mar 26, 2009 | Digital Products International Clok Smooth...
No continuous play
hold mode button for a few seconds, then select the play mode option, then select how you want it to play thruogh songs, that may be the problem..
Jan 29, 2008 | BenQ Joybee 130 MP3 Player
Won't stop skipping songs after 10 seconds!!
WAHA i've fixed it it was on repeat intro which means it plays the first quarter of he song so pretty much try to look at the repeat button and see if it is on that.....
Jan 07, 2008 | Audio Players & Recorders
Only plays first few seconds of a song
if you are using ROCBOX go to settings./ play back settings..enable party mode/replaygain/crossfade...its playing like all intros......if this is straight iriver firmware you can try settings and look in playback setting also
Nov 12, 2007 | iRiver H320 MP3 Player
I can't hear my songs
You should try to restore it. Follow the instructions on Apple's website on how to do so.
Aug 20, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
May 26, 2007 | Supersonic SC-301MP3 MP3 Player
47 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
Larry Stiles
Larry Stiles
JOHN TOPLISS
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
