Question about JVC Audio Players & Recorders
My jvc RV Dp100 cassette door won't open! - JVC Audio Players & Recorders
3 Suggested Answers
Anonymous
SOURCE: jvc rv-dp100 boom box
tune into the station you want as normal. Then on the remote, press & hold the number key for the preset number you want. This will flash in the display to show you it's set. You can preset 30 FM & 15 AM stations.
Posted on Oct 21, 2008
stynger007
  • 33 Answers
SOURCE: jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
Posted on Aug 18, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Need instruction manual for JVC rv dp100 boom
http://www.retrevo.com/support/JVC-RV-DP100BK-manual/id/316ag212/t/2/
Posted on Jan 22, 2011
JVC RV-DP100BK orange backlit illuminate LCD display stop working?
You need a new bulb installed - difficulty is semi hard , in that you must take apart the boombox , remove the shroud around the bulb , unsolder , resolder new one ..take the old one to an electronics shop to match.
Apr 08, 2013 | JVC RV-DP100 Cassette/CD Boombox
Need power cord
There a few places you can try, Radio Shack, Electronic Service Shops, Specialty Electronic Shops, and second stores. A last resort is to go online to JVC and check with customer service.
Feb 26, 2012 | JVC RV-DP100 Cassette/CD Boombox
No power cord
There are six common cords that fit most devices, Radio Shack, Electronic Service Shops, Electronic Specialty Stores, and second hand shops are more likely have what you need, as a last resort go online to JVC and link to customer support.
Cd player does not work
Try cleaning the lens using a CD Cleaner you can buy from alot of shops.
If it fails use it a few times then if it still wont play , or the disk failed to spin all together then you probably have a faulty spindle motor.
Mar 18, 2010 | JVC RV-DP100 Cassette/CD Boombox
Jvc rv-b99 cassette door jammed
Apr 02, 2009 | JVC RV-B99GY Cassette Boombox
Jvc rv-dp100 boom box
Sep 17, 2008 | JVC RV-DP100 Cassette/CD Boombox
Display light
This is the backlight, bulb 9V. must be repaced, i suggest to replace by a 12V. bulb
Unit has to be disassembly. Good luck
Mar 03, 2008 | JVC RV-B55 Cassette/CD Boombox
56 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
