Question about PfaFF Sewing Machines
Pfaff creative icon not cutting jump stitches
Posted by Sue Orr on
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Posted on Feb 14, 2008
Anonymous
  • 34 Answers
SOURCE: Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Posted on Feb 03, 2009
ken dourof
  • 980 Answers
SOURCE: pfaff long arm really long loose stitches on
You need to get the tensions set correctly, sounds like either you have not gone through the tension discs or the top tension is too loose.
Posted on Nov 01, 2009
Anonymous
SOURCE: pfaff creative 1469 instruction book
i have the books and no machine do you want to sell yours???
Posted on May 16, 2010
SOURCE: how do you backstich on a pfaff creative 2.0
For Machine Support
Toll free 1-800-446-2333
Monday-Friday 8:00a - 4:00p CST
[email protected]
Posted on Dec 10, 2012
I cannot adjust bottom tension on Pfaff creative 1.5 straight stitch
Hello Mary Jane,
Are there loops on the underside of the stitching? This means that the top tension is too loose -- increase the needle tension.
Are there loops on the topside of the stitching? This means that the top thread is too tight -- decrease the needle tension.
The user manual refers to this on pages 30 and 35. The manual is available free at
http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/creative-line/creative1_5/Manual/creative_1-5_manual_EN.pdf
Please give be a thumbs up if this is helpful, otherwise please provide more information.
Happy Stitching
Sewingirl/
Jun 04, 2018 | PfaFF Sewing Machines
How do I programme the pfaff 1473 creative designer
Check out this site, you will like where it takes you.
Stitching Stitching
Feb 18, 2015 | PfaFF Sewing Machines
Show me how to thread my creative 1473
Hello Shirley
Here is the link to a free manual
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
and the instructions for threading and winding bobbin are on pages 14 and 15
Happy Stitching
Oct 22, 2014 | PfaFF Sewing Machines
I have inherted a Pfaff 7550 and do not know how to use the maxi stitch function or to enlarge embroidery stitches
Contact a local Pfaff dealer for a manual or ask if they have lessons.
This is not as easy as the spoken word.
Mar 15, 2010 | PfaFF Creative 7570
7570 Pfaff - stitch length
Make sure you raised the feed dogs.
Jul 23, 2008 | PfaFF Creative 7570
HARD DRIVE 7570
Ask this tech kimbo322
An ex- PfaFF employee
Post your question to that tech
Jul 08, 2008 | PfaFF Creative 7570
Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Mar 18, 2008 | PfaFF Creative 7570
Pfaff creative 1469 instruction book
I have the patterns book for it, but not the normal instructions manual, shall we trade? --> pfaff [at] 0j0.org
Jan 07, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Irene Tulloch
Asmodius
Level 1 Expert
Chris Wetmore
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
