Question about Lands Phones
My Caller ID is not showingis connected to provider it comes up empty?
Posted by Maureen Coffey on
5 Related Answers
wyomugs
SOURCE: Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Posted on Mar 07, 2008
AndrewWro
  • 32 Answers
SOURCE: CALLER ID NOT DISPLAYED.DISPLAYS EXTERNAL CALL
Caller ID in the USA uses the FSK standard. For the most part, callerID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line.My switch uses DTMF. I went to the Palika electronics bazaar (I awaysuse shop number 266 near gate 5, they seem to be a little kinder toforeigners as far as the "final price") and purchased an DTMF to FSKconvertor. My US phones now show caller ID information, although usingUS number seperations ### - ### - ####. I paid R500 but you couldprobably get it for around R400 if you are willing to put in the timebargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items becausethey stuck the components into a box marked "DSL Splitter" It works toconvert the caller ID as advertised.
Posted on Sep 07, 2008
Anonymous
SOURCE: Uniden CXA15198 not showing caller id
Had a similar issue with a brand new DECT2035 uniden phone, displaying incoming call not caller ID.
Checked my old uniden phone, and it was receiving CID. So I connected my DECT2035 to that line and then lo and behold I got my CID.
After further investigation I found that CID on my dect phone wont work if its using a shared filter (ie. adsl/phone splitter). Had to find an unfiltered splitter and then just put a phone filter (that I got with my adsl modem) onto the line that is directly connecting the phone. and then WOOHOO I have caller ID.
Hope this helps you... I got my wife a little cranky over this one cos it took me over an hour and a half to try and sus this one out =)
Posted on Apr 30, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 16, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: my caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Posted on Dec 04, 2009
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do I connect caller ID
First, I'd need to know what switch you have your phone connected to and if the version supports Caller ID. Also, your telephone service must provide Caller ID to your switch (phone cabinet).
Jun 07, 2012 | Toshiba DKT3020SD Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Vtech model 2656 caller id is not working. How can I fix this?
Found this on the VTECH support site regarding your model:
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller’s telephone service provider must use compatible caller ID systems.
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause caller ID disruption, static, noise and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller’s service, transmission errors and answering calls before the ID data is received.
In addition if you would like to contact them or get more info on your phone, then use this link:
http://www.vtechphones.com/vtechui/support/faq_index.cfm
Nov 22, 2009 | Vtech VT 2656 Expandable Cordless DSS...
Caller Id function...How do I turn it on?
You dont normally have to "turn on" caller ID on a phone capable of displaying caller ID.
However, the caller ID data the phone has to pick up off the phone line when a call comes in is normally an additional (paid for) service from your telecomms provider.
Have you specifficlally requested the caller ID service from your telecomms provider ? If so, have they confirmed it is now up and running ? Are you sure your phone is caller ID compatible ? Can you borrow a phone from somebody, that you know dsiplays caller ID and try that phone on your line ?
If the answers to these questions is yes, then you need to report this as a fault to your telecoms provider who, so long as the answers to the above questions really is yes, wont charge you for rectifying the problem.
Sep 30, 2009 | Lands Phones
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Lands Phones Logo
110 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
