Most Sony Vaio systems will have a VAIO recovery wizard. Create a Recovery Media Kit using this wizard and you’ll be able to create a set of CDs that will enable you to do a system recovery on your Sony VAIO machine.
If your PC does not have this feature, you can always call Sony at 1-800-488-SONY to have them send you the disks.
Once you have either created or ordered and received the CDs necessary to restore your Sony VAIO computer, you’ll need to place the first CD in the drive and reboot the machine. The recovery process will immediately begin when the system boots. If it does not begin, you may have to enter the BIOS of the computer to change the boot sequence to the CD ROM instead of the hard drive. To enter the BIOS, tap the F2 key numerous times when booting.
REMEMBER... when you use the recoery system, it will restore your computer to it's ORIGINAL configuration from the factory. All data and programs you have installed will be GONE!
Testimonial: "thank you ! do you know by chance how to restore the system in this same computer? "
How to perform a system recovery using the VAIO Recovery Center.
Check the Link given below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C459775
Good Luck!!!!!!!!!!!
