Riso rp 3105 remove pull out drum and remove master
Posted by Rahmani Yahia on
4 Related Answers
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: Riso RP 3700 indicates that the master is still on
It honestly sounds like the unit is going to need some repair work. All the types of troubleshooting possible have been done by the looks of it. It's a hardware problem which is impossible to repair remotely.
You can call Riso at 978-777-7377 to find the nearest service center.
Sorry about that.
Thanks for your patience and understanding,
Tim
Posted on Aug 12, 2009
philipp68
  • 55 Answers
SOURCE: i have a problem withz riso rp 3105 ep
Many people have an problem. Some people have a solution.
To provide a solution you have to describe your problem!(Simple, but the hard truth. Must I be sorry for the clear words?)
Posted on Oct 04, 2012
Eaten
  • 25 Answers
SOURCE: riso rp 3105
Try with Windows 7? This is an outdated printer and drivers for such are hard to find.
Posted on Jul 25, 2013
Thomas Smithbrother
  • 3698 Answers
SOURCE: Riso RP 3105 EP How to change language I have Riso RP 3105 EP duplicator. It is english language. How to change the language to french
www.eserviceinfo.com/index.php?what=search2...riso+rp+3105+ep
Posted on Jun 07, 2015
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Rp 3105ep
www.riscogroup.com/support/downloads
Sep 14, 2014 | Ambient Recording ACD-301RF Master Radio...
Riso RP 3700 T12-305
t12-305 The master compression sensor does not go ON within 6.5 s after the master compression motor operates in the return direction.
kindly try to check your master roll and respool it. the problem could also be because your master cannot be dispose the old master properly. remove the old master and respool your master roll and initiate your machine or turn it of and turn it on again. hope to be of help.
Dec 27, 2013 | Riso RP 3700
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
Riso rp error t98-526
526 Drum set safety switch is ON, but drum connection signal is OFF.
try to remove the drum and re-install it. hope to be of help
Feb 25, 2013 | Riso RP 3700
I have a problem withz riso rp 3105 ep
Sep 18, 2012 | Riso RP 3700
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
Riso RP 3700 indicates that the master is still on the drum halfway throught the master making process and shuts down. The master has been removed. shutting down the machine does not help. Rolling on a new...
Remove the roller on which the master has been created. That will force the machine to start a new cycle. Right now the machine has thinks its in between the cycle, so to synchronise both, its been told to remove the master. Switch it off & then begin again........sodeep
Aug 10, 2009 | Riso RZ220 Duplicator
My Riso RP 3100 is not getting ink to the drum I switched out to another drum and the same thing- feels like the machine ''attacked'' the second drum the same way. Master is almost dry. Any help?
Ok,if you strip the drum open and remove the drum body there is a gear with a one way bearing on the inking roller remove that gear and clean the bearing and the sarft it is running on.If the machine is giving the same problem that ger needs to be replaced.
Remember if you strip the drum the drum is full of ink and can get everything full of ink.If you dont know how to strip the drum it is beter to get a qualified technicin to do the job.
Hope this was helpfull
Feb 25, 2009 | Riso RZ220 Duplicator
48 people viewed this question
Ekse
Marvin
Marvin
