Question about Bryant Heating & Cooling
I stupidly left damper for furnace in restricting hot air flow to house. Bryant furnace model 395CAV now flashing code 33. Can I fix this myself?
Posted by Ken Williams on
mynsawk
    New Friend:
    Problem Solver:
  • 10 Answers
You may have burnt out your heat exchanger big $$$$ to fix
Posted on Oct 27, 2019
  • mynsawk Oct 27, 2019
    You may have burnt out your heat exchanger big money To repair
2 Related Answers
Anonymous
  • 109 Answers
SOURCE: 2006 ram - restricted air flow. where are the
If your talking about no air flow, at the vents, floor,defrost, there are no doors that will restrict air flow, then you have a plugged Ac evaporater core, with foriegn matter, leaves, dirt, and oil from the ac itself, leak in evap leak cause this, as long as the blower is working on all speeds, remove the motor for inspection and evap , an other way to inspect the evap, remove the evap sensor grommet, look inside of hvac, the core will be plugged, this is an expesive repair to do. GOOD LUCK. RDJRP
Posted on Aug 16, 2009
Anonymous
  • 96 Answers
SOURCE: Bryant 395CAV furnace - goes out randomly (5 flash
its the curcuit board
Posted on Mar 04, 2011
Armstrong ultra SX 93
Restrict the flow on all of the registers on the first floor to get more flow to the top floor.
Bryant Plus 90 furnace
possible your supply duct leak or break
I have a Carrier model # 58MXA080-F-15112. I think my furnace is 30 plus years old. it isn't heating properly. The blower turns on and sometimes the flames come on, but sometimes they don't. As...
A 13 code means the furnace cycled on limit more than three times consecutively and is in a lockout for 3 hours. A 14 is ignition lockout. An ignitor does not intermittently quit working. I'm the service mgr at our shop, and I know that particular furnace model has a service bulletin out on bad secondary heat exchangers. If your lucky the filter is dirty, or the furnace condensate trap or drain is clogged. Most likely the secondary heat exchanger is plugged up and isn't allowing the pressure switch to make. Or the furnace is overheating due to it not being able to properly vent hot gas. Which would explain the high limit lockouts. Call an authorized carrier dealer so you can take advantage of the free heat exchangers and the $300 labor credit. You can also call an authorized Bryant dealer to perform the work for you. Only an authorized dealer can rectify this problem because the Bryant corp requires testing and paperwork in order to get your free parts and labor credit.
Good luck.
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Miller furnace model M3RL080 BW, code flashes open limit switch or external load on W, I bought a new limit switch, the furnace runs for 5-10 minutes then the flame goes out, the blower keeps running and...
Check your furnace filter any Limit fault code usually relates to airflow...Not enough...causes the furnace to run too hot and shut off....the furnace can be too big for your house if its new...the ductwork can be too small , also make sure your return air vents are clean and unobstructed . Your furnace can be running too long a cycle ....also if you have central air conditioning the coil for the AC in the Furnace can be dirty...restricting airflow...if all this seems ok you can usually increase the fan speed or try tunning the fan in the "On" position on your thermostat this will promote better circulation
1helpful
3answers
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
If you need further help, reach me via phone at https://www.6ya.com/expert/robert_6c29b8565d620da3
7helpful
5answers
Coleman mobile home furnace...Model number DGAA077BDTB...The furnace about a month ago started going out ( flash code- Combustion Air switch stuck closed)We replaced the thermostat on the wall and it...
I had the same errror code on my coleman furnace (3 flashes combustion air switch failed to close) but at first didnt realize there was even a light that gave codes..Anyways long story short, after searching many forums one guy mentioned about the furnace giving a false reading and talked about improper air flow ( coming in and going out) which isnt triggering the switch correctly. After thinking about it and after getting the furnace to run correctly every time I took the door off to tap on the switch (and other spots not knowing what the problem was yet) I always put the door right back on then the furnace would do the same thing (stop running). so I pulled the door off again got the furnace to work properly and left the door off and tested it. It ran great, it started and stopped like normal for a hour and realized I might not be getting proper air flow. Then I remembered I asked my roommate to change my filters for me while I was gone (which he did) and looked at them while I still had the door off and realized the filters were in backwards! which resticted the air flow so much the switch wouldnt operate fully. so check your air filters, something so stupid almost cost me a house visit by the furnace guy....this may not be everyones problem but maybe I will help someone save a house visit....I still cant believe that was my problem and the furnace is still running great.
Mar 14, 2008 • Dishwashers
Heating & Cooling Logo
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
john h
Tom Chichester
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
