Question about Samson Audio Players & Recorders
SOURCE: Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Posted on Aug 06, 2008
SOURCE: My microphone CL7 Studio Condenser Samson does not work.
your microfone needs a phantom power to work,so your fast track dont have the necessary energy to make you microfone work, so you need to conect you microfone on a pre amp then your fast track, this is gonna make your microfone work like it shold.
Posted on Jan 19, 2009
SOURCE: Samson CR77 receiver and AF1 transmitter. The CR77
There are two receivers and are used as "diversity" reception. That is, the strongest signal receiver output is used. As you move around, due to cancellation and reflections it is common for the diversity system to swap receivers. This is normal... HOWEVER there should not be a poplwhen it does this. You might experiment with the squelch level to improve performance. There is a possibilty there is a defect in your unit and repair would be beyond the capabilty and equipment you would have to troubleshoot the problem.
ONE thing is make sure the audio levels are turn up so the level is "not down in the noise" or in other words you have a good signal-to-noise ratio.
Posted on Sep 30, 2009
SOURCE: change the samson airline 77 microphone for a AMT, for sax player
Unfortunately, you don't have enough information to go on to give you a definative answer.
The Sampson Aireline will plug onto ANY xlr type DYNAMIC mic and should work.
The one thing on the AMT Elite I found said it was a "condenser" type element which means it would NOT work with your Sampson setup. Condenser mics require a Phantom power arrangement to charge the element and operate the local FET input amplifier.
If you are trying to mic a violin, the Airline 77 that was for the dynamic mics is a very poor choice as it is low impedance. Most violin pickups use a Piezo pickup which requires VERY high impedance input amplifier.
For my wife's violin we use an Autolycus pickup and an X2 wireless sytem. The pickup comes from New Zeeland and the X2 is CD quality digital wireless link. You have to make your own connector at the violin for the X2 cable was intended for guitars.
Posted on Dec 25, 2009
SOURCE: I bought a samson se50 headset microphone to go
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Posted on Jul 22, 2011
Sep 05, 2013 | Audio Players & Recorders
Aug 27, 2012 | Samson Xm610 Powered Mixer
Apr 27, 2011 | Samson C01U Consumer Microphone
Jan 26, 2011 | Samson Airline 77 Aerobics Wireless...
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Apr 05, 2010 | Samson AIRLINE HANDHELD UHF WIRELESS...
Sep 29, 2009 | Samson AirLine Guitar - Wireless System...
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Apr 06, 2008 | Samson C03 Professional Microphone
Mar 27, 2019 | Samson Audio Players & Recorders
102 people viewed this question
Hi! Maybe Fixya doesn't make recommendations, but I do :)
I just had exactly the same issue and can tell that it was a huge hustle to find the right mic for my Samson UHF cr77 (god, who comes up with these names? :))
I never been a tech guy and asked my friend who in fact is.
He said that the issue itself was kind of tricky but eventually we found a place (access-market.com) where I bought microphone with magnetic loop.
Apparently ones with magnetic loops work better.
Anyway, hope it helps :)
