Sport & Outdoor - Others Logo
emily ford Posted on Oct 25, 2019
How to assemble pacific play food truck tent - Sport & Outdoor - Others
Jason Sthilaire
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 02, 2019
Jason Sthilaire
Contributor
Level 1:
Answers
Questions
Helped
423
Points
Need assemble instructions for A cabin tent
Go to mfg for manual download or try a google search for it. It will have assembly instructions.
Instuctions for Ozark tent
Stacy, Check the attached links tent setup ,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ozark trail 8 person instant tent
Assembly Instructions for Ozark Trail Tents
How to Assemble an Ozark Trail Tent
ozark 8 person instant tent Google Search
Assembly Manual
Nothing to assemble in this kit:
Product Description Universal tent assembly and repair tool kit
1 mallet with white rubber head
1 guy rope: 15 m , colour Grey/Black
1 guy rope tightener
6 adjustable fasteners for ropes: 3.8cm x 1.3cm x 0.4cm
4 round closed hook head, zinc plated steel stakes: 23cm x 3.9mm
4 standard zinc plated steel stakes: 27.5cm x 6.5mm
4 zinc plated steel stakes: 23cm x 2.0mm x 1mm
4 zinc plated steel stakes: 28cm x 2.0mm x 1mm
8 nylon/elastic rubber rings: 29cm x 0.4cm
2 self-adhesive pathces: 7.5cm x 0.55cm
Can not assemble spiderman PLAYHUT tent
For anythig related to Plahut, contact Playhut, Inc.
368 S. Cheryl Lane
City of Industry, CA 91789
Tel: 909-869-8083
Fax: 909-869-7371
Playhut Where You Go To Play
Hillary ten person family tent
Step 1 Choose a spot to set up your tent. Look for level ground that's free of large rocks or other debris. Make sure you're safely away from your campfire. If it's possible, pitch your tent away from your kitchen area as not to bring animals too close should they be attracted by the smell of food. Once you've chosen a spot, clear the ground of small rocks and sticks to give you a comfortable floor to sleep on. Step 2 Unroll your tent. Put the rainfly and poles aside. Open the tent body so it lays flat on the site you chose. Orient the door so it faces in an accessible direction. Step 3 Take out the tent poles. A basic Hillary tent will use two long poles for the tent body and one short pole of the rainfly. Assemble the two long poles and thread them through the pole guides on the tent body, attaching them to the holes in each tent corner to raise the tent. Step 4 Open the rainfly. Assemble the shorter pole and guide it through the top of the rainfly. Place the rainfly on top of the tent and secure it to the bottom of the tent body with the attached hooks. Step 5 Stake down your tent. You don't want to be surprised by a storm in the middle of the night or while you're away from camp. Stake your tent even if the weather is clear when your arrive. Use a stake at least in each corner of the tent. Find a rock to hammer them firmly into the ground.
2helpful
My tent is unsafe, I have no idea how to make completely safe. I like to go camping in the northern woods, bears like to sniff and bump my tent.
Are you keeping food inside the tent?
Bears usually will not come near humans unless there is food smell coming from within the tent.
I also camp in the north woods and generally its the coyotes that are daring enough to come into a campsite. Also they use coon dogs for hunting bear which falls in public camp season and they roam about to track bear. My personnal best defense is to keep my chainsaw just inside the door as being a camp host I find myself being alone in site untill my guests arrive. The chain saw noise is a good defense to scare off anything because its very loud .And yes Ive actually had to run it one night in Particular when my site was surrounded by a pack of coyotes and they were right outside. KEEP ALL FOOD AWAY FROM TENT AT ALL TIMES. Raccoons also are very daring and will come on site even when your there if they smell food and are smart enough to open water jugs with their paws the trick to keep them out of your food is to put the coolers under the bench part of the picnic tables so the lids cant be opened.Im a very ex. camper and can give tips all day long
We need help with setting up coleman 13x9 forrester tent
General tent setup instructions:
thread assembled poles through sleeves
connect one end of poles into tent corners
1 by 1 connect the other end of the pole, work front to back and the tent should assemble quite easy.
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
