Question about Freezers
Danby freezer chest sounds like it's "swishing" inside about every 20 minutes. Quite loud. It’s only 4 weeks old
Posted by Darlene Bird on
3 Related Answers
Anonymous
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
Anonymous
  • 3 Answers
SOURCE: Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Posted on Nov 21, 2008
lenoradavid
  • 4 Answers
SOURCE: Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Posted on Jan 07, 2010
Every week the freezer shuts off and we have to turn it completely off and start it again. the freezer is only one month old.
Good day,
This issue should be left up to the manufacturer. Everything on the machine is under warranty.
Call You selling dealer on how to get a warranty call set up. It should be free to you.
Nov 22, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Can't find out where to register a warranty
You can register your freezer on the link below.
https://www.danby.com/registration.php
Good Luck and please rate 4 thumbs up for the free answer
Aug 28, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
HOW TO FIND REGISTRATION AND WARRANTY IN CANADA
You can register and warranty the Danby at the link below for Canada.
https://www.danby.com/registration.php?ln=CE&
Jul 14, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby 3.6 cu.ft. freezer is not freezing
the best is to check the wires at the compressor start device to make sure it has 120v and if it does the compressor is bad and if it doesn't the replace the themostat.
Larry
Nov 25, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Freezer Expert? Answer questions, earn points and help others
