Question about Kenmore Refrigerators
I have a Kenmore upright freezer the power went out next day the alarm was beeping I press the reset button it stops flashing from 6 to-3 but the red light on the reset button stays on,the next day it’s back beeping again
Posted by Jim Lorenz on
5 Related Answers
Anonymous
SOURCE: flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Posted on Aug 20, 2008
Anonymous
  • 121 Answers
SOURCE: freezer alarm
nana,
Your defrost elements are not working or the inlet to the evaporator tray is clogged, if you haven't gotten iny icy water build-up in the bottom of the fridge you will soon. This may require a service call.
randy320sgi
Posted on Feb 11, 2009
Anonymous
  • 103 Answers
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Posted on Jun 12, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER.
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Posted on Sep 26, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: We have the Kenmore frost free, 20 cu. ft.
Faulty alarm.
Posted on May 29, 2010
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
My freezer is a kenmore mdel #25323725100 , my power went off for about 2 seconds and the alarm will not go off and the quick freeze will not work . HOW CAN I STOP THE BEEPING AFTER 6 HOURS
A Big hammer? or have you tried turning it off at the mains for about 15 - 20 mins then back on again that should reset it.
ThanksTalkAppliance.co.uk
Apr 18, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Jun 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Flashing power light on Kenmore upright freezer
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Refrigerators Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
