SOURCE: casio till make ce 3410 Error
Hi. we don't have this model. it is very old now. But, it is probably similar to some of ours, so I'll give you the usual info, and it will probably work.
The first thing to do is turn the key to each mode, and press your CASH key. If the drawer opens, then that was your problem.
If it doesn't, then try a flag clear:
Turn the power off at the wall.
Hold the RECEIPT FEED button down while turning the power back on at the wall.
Wait 5 seconds.
Let go of RECEIPT FEED.
You should see 'FFFFFFFFF' on the display.
press SUBTOTAL.
It should print out.
Turn the key back to Reg mode.
If you still have trouble, just let me know.
Mark
SOURCE: Casio CE-3700
Usually EO8 means that there has been clerk numbers programmed into the machine and you haven't signed in. To reset the registers just make sure to take all batteries out and keep them unplugged for at least 45 minutes and that will drain all the internal memory from them. Then you can reprogram them the way you want. :)
SOURCE: Unclearable error message TE-4500f casio
Hi.
Yes, it thinks there is a printer jam. It may be the cutter. This can get stuck if someone tries to pull the receipt out before the machine has finished cutting.
There should be a small thumbwheel on the receipt printer with instructions describing how to wind the wheel to bring the cutter back. Make sure the mark is in the small window as the picture shows.
Some early models had a manufacturing fault that caused the printer to fail from time to time. It was replaced wth a new type of printer. If you have the new one, there are two motors on the receipt printer. If you have the troublesome one, there is only one motor. Casio agaents were replacing them for free since they gave so much trouble.
Mark
SOURCE: Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
SOURCE: its a casio ce 6100
You have to close the cash drawer to make a sale. E11 means drawer open while sale in progress. If that doesn't fix it, check the wiring to the drawer, especially the brown wire.
For anyone needing a Casio CE-6100 manual, go here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
