Question about Light Office Equipment & Supplies
Digital scanner PANSCN08 displays error light and will not turn on or allow uploading of scans on disc
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 20 Answers
SOURCE: Scanner Error
Some electronic equipment such as printers and scanners need to be "calibrated".
I recommend you follow the directions and allow the Scanner to calibrate. This may result in better scans and for printers, better printouts.
Posted on Mar 30, 2009
Anonymous
  • 27 Answers
SOURCE: Epson Stylus Photo RX510 "scanner error"
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppp22
Posted on Sep 04, 2009
Scanning is backwards
I just got my scanner yesterday and had the same problem with my FIRST jpg. I looked for a solution and found your posting. I had scanned one page of the instruction booklet from the center fold outwards, not in the direction of the text, but rather sideways across it. That image was mirrored. I did another scan in the 'proper' direction, that is, from the top of the page to the bottom, both as a jpg and a PDF and they came out in a normal, readable form. Perhaps you need to do it a few times if you haven't already? Have you tried calibrating it?
Jun 20, 2013 | PANDIGITAL PANSCN08 Handheld Wand Scanner...
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
One of the pictures has got a file error. it doesn't allow me to delet it and once that file error happens it makes all the pictures have a file error too. so i am unable to upload pictures becuase as...
FIRST OF ALL CONNECT TO YOUR PC UPDATE YOUR VIRUS DEFINATION AND SCAN THE MEMORY TO RULE OUT ANY VIRUS.AFTER BACKING UP ALL YOUR PHOTOS FORMAT THE PHONE MEMORY AND THE MEMORY CARD AS WELL. THIS WILL SOLVE THE ISSUE.
REGARDS.
PLZ. RATE THIS
Jul 02, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
I am getting a disc full error as I scan a picture.
Click Start
Click My Computer
Right-mouse click on the icon for the 'C:' disk-drive.
Click Properties.
What percentage-full is displayed?
May 15, 2011 | Canon CanoScan N670U Flatbed Scanner
2,178,0 When scanning,
Try this
1.Open the CanoScan Toolbox.
2.Click the Save option.
3.Put a check in the box that states "Display the Scanner Driver".
4.Click Scan.
5.Click the Advanced Mode tab.
6.Make sure Select Source is set to "Platen".
7.Click the Preview button at the top left.
If the error still occurs, then most likely it will be a service issue.
One thing to check...see if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner. If you get no light, then as mentioned before, then it will most likely be a service error.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
Nov 06, 2009 | Canon CanoScan 8400F Flatbed Scanner
Dear Experts, My Lexmark 2500 series printer will allow me to scan pictures off of it but, when it comes time for me to put those pictures i scanned onto a disc, or if i try to upload them to myspace or...
You need to find a program that will transform your scanned images into a format that internet websites recognize. You can start by reading the Lexmark manual and learning about formats that it uses for scanning and filename extensions. Then report back about what you found.
Oct 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How do i scan a picture to facbook?????
Scan your picture using the scanner that you own, save the scanned picture to your hard drive. Log into facebook, then go to where you upload pictures and upload the scanned pic you just saved.
Sep 10, 2009 | HP Pavilion dv6000z Notebook
Scanner Error
Mar 30, 2009 | Kodak I660 Flatbed Scanner
Problem with CanoScan Lide 500F
I would reinstall the driver first. Get the latest ScanGear and Toolbox from the Canon Website.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=11011
Do you have any other image devices such as a Multifunction (scanner,fax, printer) or digital camera attached to the computer?
Jun 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
When scan job is sent a start failure error comes on the display
Don't worry about the clean roller message. It is just a reminder much like your scheduled maintenance light that appears in your car.
Start Failure can occur for a number of reasons. When you get a start failure message close your scanning software and reopen it. Sometimes your connection may degrade if left idle. If that doesn't work shut down the scanner and pc. Turn on the scanner and wait until it is fully initialized before turning on the PC. These steps have resolved that problem for me. Lacking a manual, I just try things. Good Luck
May 07, 2007 | Kodak Digital Science 2500D Path-Through...
18 people viewed this question
Top Light Office Equipment & Supplies Experts
Marvin
Marvin
Copy-Tech
Level 1 Expert
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
