Question about Maytag Refrigerators
Maytag refrigerator modelmfi2269vew1, how do I program a new main circuit board?
Posted by Martha & Dick... on
Jorgie Navito
    Master:
  • Maytag Master
  • 357 Answers
Fridge keeps beepingor buzzing:The following is for Frigidairemodels but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls
  • A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open
  • When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
  • The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset
  • A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Posted on Mar 26, 2020
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: refrigerator honeywell model number 88031 melted circuit board! Where to get parts?
any refrigeration supply company could order that part for you just give him model and serial numbers of the refrigerator and number on the board and they can help you
Posted on May 13, 2009
Anonymous
  • 949 Answers
SOURCE: burn marks on circuit board
This can happen over time, the connection points get a little resistance build up and discolor from the heat. This resistance comes from the moisture, steam and spills. The protective devices on the board and machine are designed to fail safe.
I would suggest replacing the board after inspecting the wiring harness from the board down through the door and to the motor.
Posted on Apr 25, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: mzd2766ge Maytag refrigerator not cooling but
Hi, Most sites have an exploded view that shows where it is located...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 20, 2010
Anonymous
SOURCE: where is the main circuit board located on a
it is located in the rear of the fridge behind a metal panel.
Posted on Nov 02, 2011
novaco
novaco
SOURCE: replaced circuit board, refrigerator wont allow programming, just says PE0 000
Dear joe, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
Posted on Jun 29, 2012
2answers
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
1helpful
Replaced bad circuit board and now we cant program
There is always the cance of a lemon when buying elecrtonics but there should have been instructions that came with the new board that will instruct on the set up of the new board. If not I would give the manufacturer a call and they usually have a tech line that may be able to talk you through it. Good luck
1helpful
Temp control is flashing and clicking
you will have to have the jazz board replaced . very common problem . i have one in my own home . . this is the main control. and the only correction . A Maytag problem .. new boards have been revised and do not have the problem .. **** ,. have been doing maytag since 1950 's // hope this hepl.s if your do this service your self ( read the instructions good . as when your finish you wll have to program the control for your model .. **** . .its a easy job but you have to finish it properly.. mm
1helpful
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
1helpful
Malfunctioning Maytag and memory board flashing
You need a main control board and it will have to be programed but the new board comes with instructions
1helpful
Frozen code
did you change circuit board ???? youll need to reprogram the refig, there should be a paper that came with the new part( if indeed youdid cahngeit) if not there should be underthe right front corner of refig tapedup under behind the toe grill a tech sheet in which they should explain "programming your refrig"
Defrost Problem
the first thing to check is the defrost heating element, then the defrost limit switch, if good, then its probably the main circuit board.
Refrigerators Logo
Top Maytag Refrigerators Experts
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
gbob59
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
