I need a replacement volute for aefl320hd where can i get one
Efl320hd correction
Posted by earl r rizzo on
I have a leak from the bottom of the pump
Also, check for the actual mechanical shaft seal, they leak, and appears as if it's coming off of the wet end. Making it look like the drain plug could be leaking, or the area between the volute which is the pump housing, and the cover, this would normally be a failed gasket or O-ring, depending on the brand. Sometimes just tightening the cover to the pump housing correct this issue.
Jun 08, 2015 | Pool & Spa
Magnetek 7 187400 20 cleaner booster pump
if you need the impeller and volute you also need seals sounds like it ran without the filter pump on might be better buying a new pump when they get hot they distorte and will leak also PVC pipe is probably distorted youll have to replace the distorted pipe also
Jul 14, 2014 | Century Pool & Spa
I have an Emerson spa pump 1081/1563 and the volute is cracked but the pump works. Where can I find a replacement or can it fix the volute myself?
Go to emerson.com then enter model and look for the parts section, you can find repair manuals parts etc.
Jun 09, 2014 | Pool & Spa
I am replacing a Aqua Flow master XP2e- 2 1/2 HP- 48Y frame model # 05525661-1
must pull out just a little to clear tangs on pump make sure to see side of motor for wiring
Jun 02, 2014 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
How to replace a Pentair dynamo strainer pot?
I believe the pot is screwed into the pump body/volute. Lift the complete pump enough to turn the entire pot counter clockwise, to unthread it off of the volute.
May 12, 2014 | Pentair Garden
Just purchased an executive 56 waterway pump. need to turn the volute to match existing plumbing. Do I just remove face plate, undo main bolts and reposition or is it more dificult??
It is actually easier...do not remove the face plate, just the thru bolts. Once all 4 are released turn the whole pump in the direction required and reinstall the thru bolts.
Done!
John
Oct 13, 2010 | ADVANTAGE Waterway Executive 56 Frame Spa...
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
How do I remove the Inlet and Outlet PVC pipes attached to the Volute? They may be sealed with a sealant or glue and am not sure if I need to remove the Volute bolts first.
You just have to cut the pipes in a place where you can glue them back together with a coupeling. If you overheated the pump though you may have warped the pipes and will need to go back far enough to get to good pipe and replace it all the way up to the pump. They just screw into the pump and you can seal the new ones with silicone or teflon stick or tape. Don't use pipe dope as it is not good for plastic.
Nov 02, 2009 | Polaris Pb4-60 Volute Polaris Booster Pump...
49 people viewed this question
Ekse
Marvin
Marvin
