Question about Dirt Devil Vacuums
Belt for dirt devil powermax - Dirt Devil Vacuums
Posted by Greg Hall on
Megan
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 14 Answers
You'll need a model/part number to be able to figure out what belt you need.
Posted on Oct 29, 2019
5 Related Answers
Anonymous
  • 152 Answers
SOURCE: dirt devil vacuum belt
on the bottom of vacuum ther are 4 screws take them out then a cover should expose the roller the belt is right there
Posted on Jan 23, 2008
Robert Pagliaroli
  • 294 Answers
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 24, 2009
Anonymous
SOURCE: where is the belt on the dirt devil vision turbo
the belt is to the left of the brush. You need to revome the plastic covering (4 screws) to see it.
Posted on Dec 27, 2009
Anonymous
  • 50 Answers
SOURCE: how to put the belt on the deit devil breeze
Here is a detailed discription on how to change your belt. Turn the machine compleatly upside down and place head on a flat surface. There are 4 screws to take out, then remove the base plate. Near the back of the channel the belt rides in you will see a stright silver shaft. Place the new belt over that shaft. The put the brush roller through the belt, so the belt is in the notched out section of the brush roller. Grab both ends of the brush roller and pull till the brush roller is back in it's origial spot on the base of the vacuum. Turn the brush roller 3 compleat turns backwards, then do the same forward to seat the belt. Put back on the base plate and put back the 4 screws. You are now ready to vacuum.
Posted on Apr 09, 2010
VacuumRepair
Chris Jones
  • 438 Answers
SOURCE: How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
Posted on May 07, 2010
What size of belt do i need for dirt devil classic M08100
Hi! This hand vacuum takes a Dirt Devil style 1 belt. I have included a link where you may go to purchase the belt if needed. Hope this helps!
Style 1 Belt 2 Pack
May 03, 2014 | Dirt Devil Classic M08100 Bagged Handheld...
Why does the belt keeps comming off
Hello! If your belt keeps coming off, this usually means the belt is stretched and needs to be replaced. The Dirt Devil Breeze takes a Dirt Devil style 4 belt. Follow the link below to purchase the replacement belt. Hope this helps!
Style 4
Apr 28, 2014 | Dirt Devil Breeze Bagged Upright
I need a new belt for my Dirt Devil RoomMate. Where can I get one? Advise
Your Dirt Devil M084000 uses Dirt Devil Style 7 Belt - 2 Pack. Part # 3400615001 according to the parts manual for this vacuum cleaner, as well as the Dirt Devil website.
Here's a link to the belts online at our store;
http://www.govacuum.com/ddp126.html
I hope this helps you! Please rate the review as helpful if this helped you find the belts.
Thanks,
Chris
Mar 20, 2010 | Dirt Devil M084000 RoomMate Upright Vacuum
Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
Mar 04, 2010 | Hoover S3606 Bagged Canister Vacuum
Change belt on dirt devil vacuum
It largely depends on the model you have. However, you can get any Dirt Devil replacement belt here:
Dirt Devil Belts
Oct 22, 2009 | Dirt Devil Vacuums
Belt keeps breaking on dirt devil 85335
check and see if the brushroll still turns easy. if it doesnt, u may need a new brushroll which can be found on ebay, or dirt devil's website
Nov 23, 2008 | Dirt Devil M085580 Featherlite Plus...
Vacuums Logo
145 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
